hmmmmm, I wonder what Jrichker meant by probing both wires of the unit when it is only that single red/white wire...
Thanks for the help guys.
Oh yah, since I bypassed the heater core, can I get rid of the hard coolant lines that the ECT plugs into? Can I move the ECT somewhere else?
The ECT is located in the heater feed tubing on the passenger side and has two wires.
The wire colors are lt green/yellow and black/white.
The ACT is located in #5 intake runner on the driver's side and has two wires.
The wires are lt green/pink and black/white.
The water temp sender for the dash gauge is located on the driver's side and has a single wire.
Probe the ECT to get the temp readings if you want to check the water temp gauge for accuracy.
Pin 25 ACT signal in. at 50 degrees F it should be 3.5 volts. It is a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage readings will be lower because of the heat transfer.
Pin 7 ECT signal in. at 176 degrees F it should be .80 volts
The ACT & ECT have the same thermistor, so the table values are the same.
Here's the table: The values are +/- 15%, so don't get worried if your readings vary a little bit.
Voltages are measured across the two connector pins of the sensor with the sensor connected. Some safety pins used to probe the connector from the rear will be helpful
50 degrees F = 3.52 v
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
212 degrees F = .47 v
230 degrees F = .36 v
248 degrees F = .28 v
Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
212 degrees F = 2.07 K ohms
230 degrees F = 1.55 K ohms
248 degrees F = 1.18 k ohms
