Progress Thread The Mach Returns - Update/build thread
squeak93
2,342
414
164
Joplin, Missouri
About 11 years ago Iet this beauty go and regretted it. We just had our youngest and my company I worked for sold for the 4th time. Jan 9 was her birth date and we had new - TERRIBLE - insurance. We got a 12k bill for that and well given the uncertainty and huge bill - it was obvious this needed to go. I sold it to a good buddy who had it till he sold it for a divorce then another buddy took care of her for a while (I live in mo, it went to tx, then back to ar). That friend sold it about 6-7 years ago (offered to me but I was way out of state working somewhere else with emissions testing etc). I said dumbly no and it disappeared. I had looked for it a few times when we moved back to MO in 2021.
Last March she popped up on Facebook marketplace back in Missouri - only about 2 hours from me (near Branson). It was WAY overpriced and had a few bruises but still the same overall car. My buddy traded it into a dealer and the guy who bought it from there still had it.
I had a SWEET swb cateye I had built and really didn't want to get rid of it, but since a SXS and a Truck, toy money was spent -something had to go. I eye balled it for weeks. Finally sent a message to the guy and talked back and forth a lot to confirm it was in fact the same car. Finally negotiated a reasonable (probably too high still, nostalgia got me). I listed the SWB for sale and it sold NEXT day (guess it was listed too cheap lol).
So, she's been back home since last year.
Since getting her back we've rebuilt the front end, adjusted some silly things. Removed the old msd 2 step, misc maintenance items, fixed front end paint and rock chips in a few places, added adohan wheels/nittos tires/DR's, lowered slighly more. Strill trying to nail down the retune as it came with a basic old sct3 canned tune that felt flat. Now Archangel out of Tulsa is remote tuning and my sotp feel says she's back alive again.
Car did come back with a mac o/r prochamber vs the o/r H it had, still a mac catback. It now has steeda weight jacker lowers vs the adjustable team z ones with bob durant drop brackets. I built a 31 spline rear before I sold it but recently changed from the 3.55 to 4.10s (holy crap is 1st gear short). It now has an MGW shifter (I honestly like the steeda triax it used to have better), a few other items I'm sure.
Only 15k miles were added to her in over 10 years. I need to get some better pic locations other than my driveway.
Then did some more work on the rear suspension. Currently cutting a 1.67 60 ft time on a 275/40 17 hoosier quick time. Looking for those elusive 1.5x's which is about all this thing can likely muster given current power levels.
Rear setup - steeda weight jackers, bmr lca brackets (Welded in), team z double adj uppers, 31 spline, frpp cover, moser studs, on eibach sportlines (yes I know they hurt but man it sits nice) and Koni single adj shocks.
The main issue i have with this setup is sway bar mounting. Due to the angle of the LCA weight jackers, it made the sway bar sit almost 1 inch off the ground behind the rear pumpkin. I "fabbed" up a bracket to lower the front mounting hole of the sway bar 3/4 of an inch lower which got the bar to ride correct height in the rear but the front arm now sticks out like a stubbed toe.
I don't think a true "anti roll" bar is the right call for a car that see's the track less than 6 times a year (you could argue that for any of the rear suspension mods I suppose).
Some updates here.
Hidden raptor shift light (behind center ac vent) installed and auto dimming with a functioning PWM and 5 pin relay controlling ground cycles. Doesn't blind me to death at night. Total pita to wire up abut awesome now that it works.
Rear suspension got sorted again. We couldn't get the ride height high enough with the weight jackers AND sportlines so I swapped in some rear eibach drag springs and was able to nail ride height to where I wanted it.
Welded in some stiffers sub frame connectors
New Motorcraft IAC that solved a whole slew if minor issues I had come to live with not realizing the stocker was slowly dying. Car no longer does odd idle issues and it was impossible to run the AC the last month or so due to not being able to push enough air at idle. Also found my ribbed idler was squeaky (ha fits my profile actually) so I replaced it and amazingly I no longer think my TOB is dying as the motor is sewing machine quiet now.
I took advantage of BBK 20% off memorial weekend sale and picked up a set of 1 5/8 polished ceramic coated long tubes. I have/had a o/r h sitting in my shop for a while now to fit. Sadly, it'll mean getting rid of the Prochamber. It's a bit bittersweet as the damn thing sits so low due to my drive shaft loop and well - its mac- but that sound though....
Lastly here is a nice pic I snapped this weekend while rocking some more miles on it.
Ok. Some updates here.
I still have yet to make it to the track to test/tweak settings on all of the suspension. I'll report back for the 3 of you reading. On top of all the suspension I pulled the upper intake and did a deep soak in my parts washer using Simple green purple HD cleaner. We degreased, de glazed (nasty stuff in there) and overall cleaned it very nicely. Then with it apart we did a lot of smoothing on the upper lid/spacer, and TB entry on the lid (did not touch TB itself), removed humps, egr tubes that stuck down into air flow path (no egr anyway). Then we ported the upper side of the plenum to smooth/curve the factory flat spots etc. Nothing too crazy and I'm sure the de greasing did more than any work I did with the grinder. Then I cleaned it like 3 more times and used about 5 more cans of brake clean to ensure no aluminum particles were left behind. Then I cleaned it again haha.
I then very carefully used a TON of brake clean and lint free rags soaked in said brake clean to de grease the intake runners on the heads. I used a vac prior to make sure no big chunks were in there from intake removal (vac'd all the prior to removing too), then carefully used a clean portion of the rags and got that honey type substance out of the intake runners on the heads. I did not use any tools or anything, just removed that gunk. Car has had a catch can for 10 years but went 85k or miles before getting them on.
Parts are starting to be collected for next surgical events.
Next steps will include the already purchased BBK 1 5/8 headers and o/r H pipe to replace my factor manifolds (yes there are better headers but cost vs hp is hard to justify), add a upr chromoly k member, a arms and dump my front sportline springs for some 14/175 coil overs on my already existing Koni's.
From there is where I worry about dollar vs HP. I WANT to do a set of Todd Warren custom Cams because I want the chop. But the chop is a lot of dough vs a FREE set of 96 cobra intake cams I have (well I need to pick them up but yeah). 20 or so hp vs 45 but a better torque band AND the chop.
I will be doing new chains, new guides (likely bigger pins on the floating guides from Shelby mikes), I have some old iron main tensioners from a 2v project year ago to replace the factory plastic crap. Then we will do a new billet oil pump gear setup so I can go back on a 2 step and NOT send a chain south.
I can do the cobra cams in the car easy enough but if we decide to do Todds cams It'll be a pull the engine task as I do NOT want to degree cams in car - that just sounds crappy. Todds cams also require injectors and likely MAF to be safe, the cobra intake cams I can safely get away with factory maf and injectors but be limited from there (255 fuel pump going in either way, this one is 23 years old lol).
So, CHOP and max effort - and budget - or some 96 cobra cams and likely still hit high 11's n/a with a proper tune (Likely do Marty O tune).
End goal is click off that 11.99 at Mokan in SW Mo air (da here sucks normally) Todds cams hit that easily but I feel I can do it with traction and cobra intake cams/LT's/k member/Two-step etc. Sadly a 12 second car is a turd by today's standards, and it needs some more umph again.
Reactions: gkomo
If you pull the motor to do the Todd cams, anything else you would do while thats out? Cost may not just be doing the cam swaps but a slew of other things since its out of the car. Just thinking along the lines of your cost vs hp thought, may become more than just the cost of the cams.
I'd like to get some carbon fiber snycros in the trans and new shift forks - I'm rough on things. But I'll likely take the WHOLE car to the trans guy so he can set the pivot ball height etc there in shop vs me getting it close. Right now, I have zero back lash on that fork and it's making my TOB chirpy. And the 3650 just needs some love from jamming gears over the years. I should do all that BEFORE LT's so he doesn't hate me.
Past that the engine doesn't leak but if we did pull it, I'd do a new oil pan gasket and clean the pickup tube really good. I'm not planning to build it at this time - lord knows I windowed enough 2v motors I'm good staying stockish power.
Reactions: gkomo
Welp...
We let the forbidden smoke out of the clutch this weekend. It was on borrowed time, so it was expected. Just not while being a hoodlum doing sanctioned burnouts leaving a show (yes sanctioned, I'm not that jack wagon). Still debatable if my tires or clutch left more smoke. :( Oh well, they'll remember that smell for a while.
So, ditching the McLeod for another Spec 2+, new alum inserts for a mcleod alum flywheel (at least that's what prior owner swears he put in- if not we'll resurface what's in there), new FRPP TOB & Pilot bearing, new FRPP clutch fork, and lastly a new pivot ball. 105k miles on the fork/ball so figured it was good insurance while in there. It should get dropped off with the trans builder end of next week/first of week after for syncros and he'll just replace the clutch since I was letting him do all the R&R anyway (I've had this trans out twice thank you).
Backstory - when I bought the car back early last year, it would BARELY drive home the 2 hours in 4th gear only, and any hill etc made the clutch slip (70 mph in 4th in a pitch black rain storm was a rough reaccuiaintance). It was a simple clutch cable failure, but we knew that clutch was sketch and not going to live forever. Well, it cut a lot of 1.6X 60 ft times but a non-water box burnout was simply too much.
Reactions: Bronco2fan
Car is getting dropped off tomorrow with Trans builder for rebuild/syncros and install the spec 2+ and frpp goodies while hes in there.
Also ordered a bmr k member with spring perches. Will reuse stock a arms with new bushings since I just put ball joints in them and trying to stay cheap until I decide on if I'll do cams/coil overs etc in the future. But really want the long tubes out of the corner of my shop and on the car.
So a bit of a wait on the trans guru and then a weekend of thrashing to install the headers/k member. A new alignment etc and just in time for winter lolz.
Reactions: gkomo
Update: sort of- parts are taking forever. Car is still at trans builder.
Got billet shift forks due to Heman himself jamming gears, All shifter key and springs, 5-R slider and hub assembly, 1st slider and hub assm. Bearings, seals, 5th bearing on main (tail shaft had been leaking since 80k - even with multiple new seals. carbon fiber synchro's.
Prob some more stuff but it'll be spec'd and blueprinted correctly and should shift like butter when all back together and broken in with the new spec 2+ clutch.
Reactions: gkomo
Got the car back. Put 100 miles on it over the weekend. Having some issues with adjustment. The Steeda adj cable and MM quadrant/firewall adjuster are OUT of adjustment and its still loose. So ordered a steeda double hook quad and found a cable throttle stop device I think i can correctly clamp onto the cable end (quadrant side) to make cable shorter. Last time I put a Spec in this car I went to a fox cable (shorter) but that routes it way to close to the headers. So, trying to keep the sn length and keep adjustment.
To be clear, we had it working fine but it was almost out of range on the cable - about 1/2 inch left and the firewall adjuster was out almost 2 inches. Still wasn't tight enough and it vibrated the adjuster closed, causing a floppy pedal (where's that purple pill?).
Quadrant will be here tomorrow to see if the longer attachment solves it w/o any other odd ball things.
Reactions: gkomo
Parts updates:
My Steeda quadrant is out to deliver today. Along with it I ordered the full timing set from Melling. I have an old school set of iron tensioners I've been sitting on for years that are cleaned up and ready to go with new said timing set. Really just after the chains and guides but it was cheaper to buy a full kit vs buying by the piece. Real goal is to dump the factory plastic tensioner. I believe I've decided to use my free 96 cobra intake cams (still a small chance I pull the trigger on Todd Warren ones).
My Kenny brown rear shock tower brace will deliver tomorrow after waiting 6+ weeks for it. Will work on that over the weekend maybe (Kids are keeping me stupid busy).
I took advantage of BBK 15% off and ordered a 300lph full fuel pump assembly. I found a set of 39# injectors locally reasonably priced. I have the LMAF laying around still that I can use the Mach electronics in (with tune) to finish opening up intake tract. End goal is to not be at the top of my duty cycle of the factory 24's and have room to grow (Todds cams certainly need and cobra cams/long tubes likely get me higher than I like).
All of that will go in when we do the long tubes and k member that have been sitting round for months.
But first - finish up this cable/quadrant debacle and get these break in miles done. I have a slip-on heat sleeve for the cable coming today as well since its all loose and now's the time to protect it from the upcoming long tube header install vs taking it all apart later to deal with.
While under the dash I did notice the hydro boost seal had a tiny bit of trans fluid on the end so that will need addressed when we have to pull it off to remove the driver side cam cover anyway. Am looking at rebuild kits but also may just slap a reman unit in there. Not sure just yet.
I'm leading a local power cruise in two weeks, so I have some pressure to get the clutch working as desired and holding adjustment. Plus need some more miles as they are not going to want to follow my pokey butt through the twisties if I'm still breaking in the clutch and can't really get on it too much. I can click off a few hundred miles in next two weeks (if things go well tonight) and hopefully finish the last of the break in at the early part of the cruise before we get into the fun stuff.
Reactions: gkomo
Steeda double hook quadrant replacing the MM one was the answer. Didn't even use the second/longer hook. First hook was enough to take up the slack of the cable, and I threaded the adjustable part on the trans down a bit more. Clutch feels good, lets out super high now vs on the floor like it did initially. Still a small amount of pedal movement once clutch is full engaged and the cable on the fork is easily able to be wiggled - yes that's a super hi-tech way to check lol. it needs some tension to hold the firewall adjuster, and I like my clutches releasing high for faster shifting and just drivability.
Now we need 375 more miles. :D
Always busy.
Kenny brown shock tower brace installed (took 6 weeks to get here). This was not as easy as I expected. First, it was a no go by myself as I do not have 10ft arms so that was most of the battle. Trying to hold bolts under car/shock tower and inside trunk at same time. Have a buddy or an unwilling wife. :D
Second, it had to be "drawn" down with bolts in the shock post holes to then mark side mount holes. And as we all know not every one of these cars are EXACTLY the same between the shock towers on the stamp tool PLUS 23 years of life and it would not touch the top of each shock tower at the same time w/o lots of help. I had to fashion some amazing washer stack spacers for just one side bolt -which I thought wasn't too bad. Dealing with the carpet (spare tire cover/board) and the nice layer of dynomat was more problematic to get things flush.
End goal is to run full coil overs down the road and solidify the chassis in the rear due to the hard launches (will have to do torque boxes maybe next winter).
Reactions: gkomo
AND still busy. :D
Installed a nice KW headunit. My CD6 actually worked but I was tired of my cig lighter, blue tooth, FM modulator for tunes and the crap sound quality.
BUT I tried installing an alpine last year and could not get the sound balanced. Had TONS of alternator whine even with ground loop isolators etc. Gave up and returned it. After a lot of research I learned I should be able to use a LC2i to modulate/throttle the rear mid/subs amps, so I don't have all bass or no bass.
Lots of wiring and a rat's nest - which I swear was clean on my bench when I soldered everything - we've got tunes and great sound quality. It's not going to win a contest, but it sounds as good or better than the stock Mach 460 - which I don't mind. And my quality while streaming XM off my phone or just songs on it is great. Plus, we can plug in car play for when we want maps up or something.
Also fixed the missing foam around the ac vents as they slide into the duct work. Last year sometime, they exited stage left when I turned the ac on, was good time driving down the road dodging foam pieces haha.
Reactions: gkomo
Made a catch can mount so it doesn't sit on top of the hydro boost any longer (with a furniture felt pad under so it doesn't knock lol). Used the old egr location and bolt to simply keep things out of the way.
Then ran some new lines - the 5/8 lines from the heated pcv to the 5/8 intake inlet posed a bit of a problem with tight radiuses etc. I am trying to get my hands on either a premade line that has a nice 90 in it prebent - that isn't $35+ or a spring tube bender big enough to do the heat/cool method to bend and hold shape. For now we are still very industrial as the 90 Degree fitting in that size was stupid long. It works for now and I'll try a few diff solutions.
We did put 200+ miles on the car this weekend. I made it to break in thresholds and got to test the shifting and suspension against an unsuspecting old school Mopar. Got WAY out on the hole shot, shifted amazing- didn't even think about it things shifted so good. Then got ran down like a rabid dog on the big end as the old Mach needs some top end help. Car ran by me like a turbo car after I was a good bus length out lol. Then did the whole open header flame show after haha. Good times. Ended up knowing the guy and we both had a good laugh when we rolled down windows to see we knew each other.
Don't mind the polished water spots- it's a losing battle when you have a giant hole in the hood. :D
Reactions: nickyb
