Weekend update:
Got the rear out of the car - man that thing was tweaked. It moved so much it whacked the exhaust, the inside of the wheel has some opposite marks on it and then of course the inner wheel well damage I pictured above. The driver side ground effect has a slight tweak since I rearranged the metal it attached too.
Getting the lca bolts out or the drag springs out was freaking tough. Things got twisty and bound up. Plus doing it by myself was a chore. Some jack stands, a few center punches (for bolts through holts) and a lot of 4 letter words and we are out.
Rear housing is fully torn down now. Aside from the obvious tube damage the rest of it appears to be ok. No twisted splines no chunks missing in any teeth etc. Getting the axles OUT - pushing in to get c clips removed took the negotiator and a pry bar to get back out but once the carrier was free of the housing they slid into the splines just fine. Will still have a shop check them for straightness but no signs of any damages to them.
I have a new (old) gt housing sourced. I have a fab shop that will jig/brace and fully weld the tubes, weld in the (incoming) team z lower brace, and re weld the bmr lca relo brackets (cut them off the bad housing) all for $200. That's a steal imho.
So this week I'll go get the GT housing and strip it down, degrease, prep etc then get dropped off at welders next week sometime (thats the goal for now).
Planning on staying with GT rear brakes so I can run a 15x10 wheel easily since my 17's took a hit - likely bent - and I clearly destroyed the tires anyways.
