Progress Thread The Northwoods Notch
  • Thread starter Thread starter Cheapskate207
  • Start date Start date Jan 14, 2020
  • 3
  • 4
  • 18
First Prev 2 of 18 Next Last
Coast2CoaStang
254
#21
  • Jan 19, 2020
  • #21
Very nice ride you have there, and hello from another Maine fox owner in Sebago.
Cheapskate207
The left one hangs a little lower
5 Year Member
Jan 12, 2020
761
541
113
Maine
Jan 19, 2020
#22
  • Jan 19, 2020
  • #22
Hey thanks! You’re right in my neck of the woods. I’m in gray.
CarMichael Angelo
8,909
234
Birmingham, al
Jan 20, 2020
#23
  • Jan 20, 2020
  • #23
You’ve done what should be the reference standard for most new Mustang owners here.
Get it running, get it safe, fix the phcked up things, replace the ugly or poor taste sht, get it looking good.drive it.
Good on you. This thread gives me hope.
Ill bet that there are plenty of hopeless people out there that’ll buy the old steering wheel and those old tail lights though.
Reactions: Cheapskate207, 90sickfox and LILCBRA
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Jan 20, 2020
#24
  • Jan 20, 2020
  • #24
Thank you sir! Appreciate the kindness and of course agree. Believe it or not; I've actually sold everything I've removed from the car through local classifieds... FB, CL, etc. There will be more to sell before the projects done!.. wait... the projects never done though
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Jan 20, 2020
#25
  • Jan 20, 2020
  • #25
Picked these up locally for future growth $150! No plans to boost it in the immediate future but some day i hope to.
Maddene
24
14
Maine
Jan 20, 2020
#26
  • Jan 20, 2020
  • #26
Yes I would have agree on the choices that you have made all in good tastes and safety. The 89 I just picked up has aV1 Vortech. I just recently bought a complete new top end. Waiting for the timing chain and new upper and lower intake to arrive before I start the swap. I will be listing my parts for sale as soon as they come off. Thanks for the tip on FB page, checked it out yesterday.
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Jan 22, 2020
#27
  • Jan 22, 2020
  • #27
Well.... sht. Looks like the heads will be coming off. I think the HG is blown at cyl 8. Not sure when they blew.. sometime this summer. Probably doing a compression check beforehand. Any other recommendations/tips?
Maddene
24
14
Maine
Jan 22, 2020
#28
  • Jan 22, 2020
  • #28
That is unfortunate. No real good recommendation, hopefully it’s obvious when you start digging into it. I have chased leaks in the past some Easy others not. Good luck.
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Feb 29, 2020
#29
  • Feb 29, 2020
  • #29
Updates:
I compression checked the car (cold).
1 - 155
2- 150
3 - 155
4 - 155
5 - 150
6 - 155
7 - 155
8 - 145
I am happy with these numbers. It also reinforces the problem is number 8 cylinder.
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Feb 29, 2020
#30
  • Feb 29, 2020
  • #30
I decided to change up the shifter. I used my pro 5.0 shifter and got a Tri Ax shift handle, hurst plate, and hurst ball. The seller was adamant that the boot would rip. I cut it to fit the handle better. I like the look a lot; if it rips I will buy a new boot and keep trying... they're only 9$.
I also picked up a used 3.5 Anderson power pipe locally for 100$. It was tarnished badly but shined up to near new with some aluminum polish! Next was a Pro-M 80mm that I scored off ebay for $105. It's calibrated for 42lb injectors and the tuner I use said I was good to swap to my 42's (future growth). I still need to clean up the Maf and get my injectors cleaned.
Reactions: 95BlueStallion and Potomus Pete
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Feb 29, 2020
#31
  • Feb 29, 2020
  • #31
Started digging into the motor....sure glad I cleaned up my engine bay and removed everything not necessary. I was really happy to see how clean everything was. No sludge, dirt or other junk at all!!
I travel a lot for work and have been super busy so I haven't had a couple days in a row to get it done, I'm hoping to yank the heads and have them checked by the machine shop next week.
Reactions: Olivethefet, Potomus Pete, 95BlueStallion and 1 other person
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Mar 3, 2020
#32
  • Mar 3, 2020
  • #32
More progress. I need to drop the heads off at a machine shop for evaluation. There are several around me so I need to find a reputable one that that can turn them around quick. It looks like the source of the leak was a nick in the head. Hopefully i can be repaired... i don't particularly want to buy new heads at the moment. What do you guys think?
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Apr 3, 2020
#33
  • Apr 3, 2020
  • #33
Had the heads gone through. Machine shop took .013 off. They also found that the spring seats were worn and deteriorating, so they replaced those. I got everything put back together.. fairly straight forward. I ended up getting new crane 1.7 roller rockers and installing my new 42b injectors and CAI. Upon firing it up the engine ran great, but was making a loud tapping noise. I'm hoping that its just the rockers/lifters being mis-adjusted but I had knee surgery (ACL and Meniscus) the day after getting it running so I haven't been able to work on it. Once i can walk (3 more weeks) I plan to install a new damper (mine had slipped a little bit and I think this was the reason I may have messed up the rockers), check pushrod length, and re-adjust lifter preload. I did not check pushrod length because I thought that geometry would be the same only taking so little off the heads. All the rockers took 1 thick shim and one thin shim and got to 18-ft/lb's in about 3/4 of a turn.
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Apr 3, 2020
#34
  • Apr 3, 2020
  • #34
Reactions: Olivethefet and Habu135
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Apr 3, 2020
#35
  • Apr 3, 2020
  • #35
Did you soak the lifters ? If not it may take a while for them to pump up. Top end tap is more than likely an adjustment issue. When you heal up check the contact patch on the valve tips. I'd think you would have done that already while shimming the rockers. Nothing like a black notch man.
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Apr 3, 2020
#36
  • Apr 3, 2020
  • #36
@90sickfox no I did not soak the lifters. How long could it take for them to pump up? I'll admit, I did not check the contact patch. I just bolted it back together thinking "it was fine before and .013 isn't much..." I was busting ass to get it done before surgery.. wanted to get the motor all sealed so it didn't sit open and apart. Also, while it was fresh in my mind. .. 6 weeks is a long time. Regretting my haste now, but, it is what it is.
90sickfox
Mar 2, 2015
6,953
5,831
213
Apr 3, 2020
#37
  • Apr 3, 2020
  • #37
I leave them in a container of oil over night if new. Used ones go straight in a container as soon as I take them out. Some people don't soak them at all. Just put some assembly oil on the tip and the let them fly. It takes a while to pump them up...sometimes up to a minute or so ( seems like longer when you are listening to a tap on a fresh build ). The key is that it should get slightly better gradually over that time frame. I just put a HEMI together at work and it took about 5 minutes for the tick to go completely away.
That contact patch is really important. That's how you verify if the geometry is correct. Should be a tight pattern across the center of the valve tip.
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Apr 3, 2020
#38
  • Apr 3, 2020
  • #38
Ok, I never even took them out. Maybe I'll run it a bit and see if they pump up. That's probably being optimistic, but worth a shot before tearing it down again. Thanks for the info man! @90sickfox
Mstng93SSP
You have a nice rear end there Dave.
3,500
184
Mililani, Hawaii
Apr 3, 2020
#39
  • Apr 3, 2020
  • #39
A lot of times the noise comes from a rocker hitting the valve cover. I know you have nice tall valve covers but it is worth a look to see if there is any marks where a rocker might be hitting it.
Chris
Cheapskate207
5 Year Member
Jan 12, 2020
761
541
113
Maine
Apr 4, 2020
#40
  • Apr 4, 2020
  • #40
I considered that. It's def worth looking into when I take the valve covers off! Thanks, great suggestion! @Mstng93SSP
  • 3
  • 4
  • 18
Progress Thread Dirty Water Racing 89 Notch Project
  • ShedBuiltMS
  • Sep 29, 2020
  • 2 3 4
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2021
Flyboy60
F
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
75K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
My 95 v6 to v8 conversion project. Advice needed
  • Stangzpride
  • Jul 27, 2018
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 30, 2018
Stangzpride
Definitely not a new member (joined in 2005), but beyond searching I'll finally be posting:) New to me 1983 4-Eye Notch in my possession now:)
  • bahndrvr
  • Jan 31, 2019
  • The Welcome Wagon
4K
The Welcome Wagon Feb 8, 2019
Olivethefet
H
New Member, New Project, Long Time Mustang Fan
  • hobbydad
  • Dec 10, 2016
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2017
FoxMustangLvr
