Ok in the past year, I have added new cylinder heads, switched from the performer intake, to the wieand stealth intake, went from a holley 600 to a edelbrock 600, went from 2:79 gears to 3:55 gears, Ive also done a shift kit to the C-4, and now have a B&M megashifter. The car just doesnt feel right. In park, the car sounds good and revs up fine, but driving it around, it just doesnt feel right. When i put in the new heads and intake, with my crappy holley carb, I used to be able to burn out in drive and not have to stick it in low but after the gears, shift kit and shifter the car went down hill. My question is, Will a incorrect installation of a valve body, mess up my performance? Like bad acceleration, not being able to do burnouts anymore, ect... I think im going to go back to my stock shifter because the B&M has been nothing but trouble. Any ideas??
Mike
Mike
And when you cant find out what the problem is, it is really frustrating.
So it's sounds like it's either your shifter kit, or shifter. I don't know too much about either, but I would assume the there would be a problem with the shift kit before the shifter. I had a Cressida that had a problem kind of like this. When I placed it into drive, it would either stall, our idle really low and rough; and I would be able to go from 0 all the way to about 55ish before it would shift again. It made me think that when I put it in drive, it was in like 2nd or 3rd; but I donno how that would make it stall. Does the amount of resistence in a torque converter varrie depending on what gear the tranny is in.
