thermo gasket
  • Thread starter Thread starter v850mustangluvr
  • Start date Start date Nov 30, 2004
V
v850mustangluvr
71
Texas
Nov 30, 2004
  • Nov 30, 2004
just curious when i change my thermostat and put the gasket do i need to put any sealer (silicone etc.) on it, and is there a certain direction to put the thermo, or will it only go in one way, dont want to mess up......
if i do need to put any sealant what kind of sealant??
also i got a new water neck or water outlet whatever its called....do i also need to put a little sealant around that too????
thanks for any help
bryanrevans
296
Chicopee,Mass
Nov 30, 2004
  • Nov 30, 2004
Make sure the core is faceing engine.The pointy thing is towards the rad.That core has wax inside and melt at certain temp 180,193 ect.Youll notice a round grove aprox same size as therm in neck that therm has to rest down in that grove gasket over that them match too lower intake.Do not over torq!!torq evenly and same time.The rtv I use VERY little mainly to hold therm in that grove.Some therm gaskets have adhesive to hold every thing inplace.If you leak them either too much rtv or the therm has fallin out of grove.
SilverFox90
80
central, IL
Nov 30, 2004
  • Nov 30, 2004
when i did mine i used only blue rtv didnt use the paper gasket and havent had any probs yet
CManT1914
3,172
Killeen, Texas
Nov 30, 2004
  • Nov 30, 2004
I used a gasket and just a little RTV red to hold it in place when I put the water neck back on there. It works fine, and it's a little extra insurance.
EDIT: Hey are you putting in a colder t-stat? Like a 180* or something? Because I just switched to a 180 when I swapped intakes, and now I think the stang is gonna run to cold now that winter is coming. Something to keep in mind.
V
v850mustangluvr
71
Texas
Nov 30, 2004
  • Nov 30, 2004
ok thanks guys.....just wanted to be 100% sure before I put it in
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
