i think my thermostat is going out, or something is fishy with my cooling.
today it is raining out, about 40 degree's or so i would guess. my car ran hotter today then it does in the 80 degree weather we had this past weekend. this is what happens, best i can explain it.
i drive the car like a grandma 98% of the time, and in the city usually. no matter what the weather, it seems to stick around 170 degree's. with alot of stop and go i see 175-185 TOPS.
so today with the weather i stated, i had a little fun going around some corners. spinning through the first few gears at about 1/4 throttle, controlled rpm's, never even saw my 4500 rpm shiftlight come on. car went up to 180 and stuck there for about 30 minutes of driving.
i stop to get some food, and it goes to 185 slowly. im waiting at the window for it, and it jerks over to 192ish, then 195.. i shut the car off thinking something is wrong. i get my food finally, by this time the car has heated up to 205.
i start it, and almost immidiately, it has dropped back down to 180 and stays there. wtf makes the temp all the sudden decide to jump? my running temps are inconsistant with the temps outside. sometimes the car will barely heat up when shut off, and jump like 5 degree's, and other times it jumps up like 30 degree's.
most of the time i never even see 180 degree running temps when warm, it is just very inconsistant. does this sound like a thermostat problem? ill list my cooling specs:
stock radiator, 170 degree thermostat, edelbrock mechanical waterpump, removed ac unit infront of radiator. temps off an autometer gauge on front of intake.
