Thermostat install?
  • Thread starter Thread starter backfocus
  • Start date Start date Mar 19, 2007
backfocus
254
Little Rock, AR
Mar 19, 2007
  • Mar 19, 2007
I am taking apart the upper and lower to figure out where the coolant leak is coming from. When I took the water neck off the termostat fell right out. I was reading in the my book that some T-stats have locking ears that you turn to lock it in place and the some have a spring like flange that holds it in place. Mine has niether, not does it have a bleeder hole and I don't see anything in or on the lower and water neck that would hold it there, just an inset on the water neck. Since I have a GT-40 lower is that gone now, or how does it lock into place, especially to re-install it? It looks like the old one was RTVed up to stay but has since came free.
Also does the spring side of the T-stat go into the lower or the other side. it fell out so fast I did get to see how it was oriented.
Thanks and sorry for the trivial question.
bloopbloob
578
Alberta
Mar 19, 2007
  • Mar 19, 2007
just did this saturday. spring side into block. mine did not lock either just a flat surface. i just used a little sealant to hold it on then bolted it all back up. no problems so far.....
backfocus
254
Little Rock, AR
Mar 19, 2007
  • Mar 19, 2007
Thanks for the help!
I hate RTVing stuff up just doesn't make sense that there is not a way to lock or hold it in place.
Any other suggestion anyone!
bloopbloob
578
Alberta
Mar 19, 2007
  • Mar 19, 2007
i didn't seal it... just a little dab to hold it, then on she went. it was some sealant made for water pumps and t-stats only, so didnt bother me to do it!
JChalfan
551
Bellevue, WA
Mar 19, 2007
  • Mar 19, 2007
There's nothing to hold the thermostat in place, except the fact it's obviously sandwiched between the block and the thermostat housing.
Seriously though, I think I usually put some rtv on the gasket surface that goes against the intake. Then I set the thermostat in there and set the rtv'd gasket over it, and that will hold it in place while you put the housing on. I think I always put rtv on both sides of the gasket. Not a lot, just a thin layer.
Jeff
Aryan15
236
CA
Mar 19, 2007
  • Mar 19, 2007
you can use a rubber band to hold it against the t-stat housing while you bolt it on. Then just snap it and pull it through.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 19, 2007
  • Mar 19, 2007
yep that is what I do...use a pen or something and fish the elastic through the housing through the stan and back out the housing holding the stat against the housing....once bolted in place remove elastic
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
A
Engine 04 GT timing chain issue
  • AwesomeX1103
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 5, 2025
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
