roush 97 New Member Aug 28, 2003 86 0 0 Illinois Oct 10, 2004 #1 Oct 10, 2004 #1 I was planning on a new intake for my car. I figured while I was at it I should do the heads and cam. The intake looks like a fairly simple swap. After I get the old intake off, how much more work is involved in replacing the heads and cam?
willys1 Active Member Dec 2, 2003 1,004 1 36 New Jersey Oct 10, 2004 #2 Oct 10, 2004 #2 Pretty much taking apart the entire top half,and front part of the engine
Michael Yount Mustang Master Apr 10, 2002 9,039 6 79 Charlotte, NC Oct 10, 2004 #3 Oct 10, 2004 #3 Replacing an intake is about 20% of the job that replacing the cam/heads are. Be sure you degree the cam before measuring p to v clearance.
giddyup306 Founding Member Oct 22, 2002 3,041 2 59 Oct 10, 2004 #4 Oct 10, 2004 #4 If you have never done a h/i/c swap before I suggest you locate someone to help you out.
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Oct 10, 2004 #5 Oct 10, 2004 #5 You take everything off besides (view from outside) the block/oil pan/ and pistons... If want to do it right it can take some time...it helps a lot if you have some friends to help you out...
W wytstang Mustang Master Mar 14, 2004 4,988 4 78 Summerville,SC missing South Fl. weather :( Oct 10, 2004 #6 Oct 10, 2004 #6 Here's a guide to help you out http://users3.ev1.net/~voodoostang/headsswap.htm good luck.
