This setup pretty good for the street??
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
93 roller long block
Thumper heads and bcam combo ( on his site)
Edel Performer carb manifold
Holley 4160 600cfm carb
2000-2500 stall
lentech VB (where can i buy these?)
4.10 gears
and my exhaust that is on my car now
how much hp tq would this be??
any thing i need to change for the better?
What whats the power range on the b cam/ what stall speed should i get???
Sounds good to me aside from the 4.10s for highway; but then again you are runnin an AOD. What's your 1st gear? No idea bout the stall speed I dont bout all that. What is Lentech VB? You gettin an intake with that combo, im gettin an 'Air Gap' to replace my 'Performer' if u want the performer for like $50 plus shipping. I didn't read your sig either so I dunno if you already got em. Runnin larger exhaust or just mufflers? PM if u want the intake. Oh yeah I have an o/r H pipe if u want that for $50 as well.
Anthony
so will the 2-2500 stall work good with the b cam???
also i will get rid of my smog pump, my ac that doesnt work and i will never use anyway. and get underdrive pullies.
My exhaust consisted of:
flowtech equal shorties
unknown h pipe( looks like it could be stock with cats cut out)
and some unknown mufflers, it stops before the rear axle.
What do i do about o2 senors, just cut the wire and leave them in there?
Also what do i do about guages??
Will i be required to buy a whole new ignition??
Also how much do you think i can sell my old efi stuff for?, if i decide i really like carb....
i got the stock harness, i have stock distributor.
i have a Painless wiring harness( goes for like 450$ in summit)
MSD coil and some aftermarket distributor.
And when the swap is done, what all exactly will be useless and will need to be removed???
Don't cut the 02 sensors.
Take them out and go to a parts store and get a oil drain plug the same size.
That way if you want to go bace to efi you don't have to buy new 02's.
Just a thought!
And f you sell the painless kit let me know what you want!
Thanks,Eddie
[email protected]
