  • 2005 - 2009 Specific Tech
those with 4.10s
  • Thread starter Thread starter maxima
  • Start date Start date Nov 18, 2007
M
maxima
146
  • Nov 18, 2007
after u guys did your 4.10s , from a roll if you got on it just say 20mph with the stock gears the car down shifted great a took off , now with the gears it dont jump as hard , my thinking is the gearing differant and the car is going to down shift at dirrerant speeds or harder at others now , sound ablut right , and does anyone notice this as well ?????????? thanks
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Nov 19, 2007
  • Nov 19, 2007
Do you have a tuner to reprogram for the new gears? If not the computer is getting false RPM to MPH readings. My auto responds tremendously at nearly any MPH/RPM.
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Nov 19, 2007
  • Nov 19, 2007
Do you have a tuner or a speed calibrator? If not, it's possible that your harming your car.
steedman07
176
Connecticut
Nov 20, 2007
  • Nov 20, 2007
Ya, I just pet mine in, and in drive at 20 mph, it downshifts to first like an animal...
I would make sure, like posted above, that you tune for it...
M
maxima
146
  • Nov 20, 2007
my car is tunes allready for the gears
fobra559
Nov 1, 2007
721
Lindsay, CA
Nov 21, 2007
  • Nov 21, 2007
Are you sure it's tuned right? Who did the tune?
kooldawg6
Aug 31, 2006
1,679
Central VA
Nov 21, 2007
  • Nov 21, 2007
If you have the stock tune, but has been recalibrated for the 4.10s then it should shift at exactly the same RPMs as it did before. The only diference will be the speeds at which it shifts should be higher. If you are running a custom tune, then everything could be different, but I've had no problems with mine ever.
I'll ask the guy a bunch of questions when I get my car dyno tuned, but there are settings on the SCT for changing shift points both with RPM(which I do know about)and MPH(which I know nothing about).
Five Oh Brian
552
Pacific Northwest
Nov 21, 2007
  • Nov 21, 2007
I have 4.10's and automatic, and I retuned the shifts by rpm, like KoolDawg, not by mph. That may be the difference for you? Maybe it's downshifting at too low an rpm which would result in bog. Glad I have a big stall converter as the revs are always up when I give it any gas, even if the trans doesn't downshift.
If I punch it at 20 mph, it kicks down to 1st and goes sideways on a dry day (with T/C off). Same thing at 40 mph, it kicks down to 2nd and goes sideways on a dry day. Heck, I was doing 60 mph the other day in the rain on the freeway when traffic cleared up, so I punched it, trans kicked down to 3rd and I went sideways into a controlable drift.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
