revhead347 said:
I swear that the blocks Ford sells to the aftermarket are rejects that they aren't willing to put in cars and warranty. I have heard some horror stories about new Ford blocks. I would just use an old one, there are plenty of them out there.
Yes, I've heard the same.
A 347 is a .030 overbore 302, which is nothing. The cylinders still aren't thin enough to make a difference. If it really bothers you, you can always build a 342, which has no overbore.
A 347 not only is a 0.030 overbore, it's another 0.400" of stroke, which is huge.
The power output of the engine is completely dependent on the flow capacity of the heads and cam. Once the flow capacity has been obtained, you are at max power. The 302 will reach the flow capacity of the combination, but you will have to spin it higher to get there. There are a few factors that might cause a 347 to make a hair more power, but the difference is negligible.
If you use the same parts from the 302 onto the 347 yes. If not, then no.
Kurt has some very valid points. I touched up on a few of them because he wasn't being descript enough.
Why does the 347 make more power than the 302? More cubic inches, yes, but that's not what I'm trying to get at. Piston speeds are increased because of the increase in stroke. The piston has to travel a further distance in the same amount of time. What does that mean? Greater speed.
When speed is increased, the air volume must too. Think of it this way: When the piston is traveling down in the bore on the intake stroke (intake valve open), it's traveling faster than it would with a stock 302 stroke. This in turn, creates a harder suction affect, pulling more air in, helping feed the increase in cubic inches.
Piston speed = Stroke x ( RPM / 6)
On a 302 with AFR 165 heads, it seems to run out of steam at about 6000 RPM. This is a piston speed of approximately 3000 ft/min. The same piston speed can be matched by the 347 at ~5300 RPM. By spinning the 347 to (a very safe) 6000 RPM, you are now acheiving a PS of ~3400 ft/min; something that would take the 302 6800 RPM to acheive.
To take advantage of these increased speeds, you need a cylinder head, camshaft, and manifold that can supply the adequate amount of air to feed the combination.
This is very simplified still, but I think it helps contribute to the discussion...
Joe
