throttle cable removal and install
spiegs
boston ma
sup guys, im replacing my throttle cable on my 93 5 speed. i understand unbolting everything in the engine bay and then the little plastic piece that fits into the top of the pedal arm. im assuming i manuever my way in there and pop it up and out with a screwdriver? how to i press the new one back in? its quite difficult to reach all the way up there and get any type of leverage on anything. any tips would be appreictaed!
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
17,302
5,588
193
polk county florida
I have to replace the gas pedal in my 89. My drivers seat is out to make it easier.
All I can remember is it was a MAJOR pain!!!
I'll go out to the garage in a few and see if I can jog my memory.
If I have gas pedal nightmares tonight it WILL be your fault!!
  • Haha
Reactions: spiegs
General karthief
Mod Dude
Aug 25, 2016
17,302
5,588
193
polk county florida
It does not just 'pop up', the plastic piece that fits in the hole of the pedal is split on the back side, the side you can't see, I used a small pair of pliers to squeeze the plastic together enough to come out and the cable will come out the slot.
spiegs
boston ma
i guess getting the old cable out isnt my biggest concern (still a concern) but getting the new plastic piece pressed into the pedal arm. is this something i do with my fingers? removing the actual arm doesnt look like an easy job either
General karthief
Mod Dude
Aug 25, 2016
17,302
5,588
193
polk county florida
The pedal un bolts from the floor, makes removing the cable easier, then just slid the cable in the slot and push the plastic piece in the hole, bolt the pedal back to the floor.
Mstng93SSP
You have a nice rear end there Dave.
2,300
174
Mililani, Hawaii
The plastic piece will pop itself into the hole. Like thief said, unbolt the pedal, then it is easier.
I have done this several times. Unhook the throttle body side of the cable, then once the pedal is unbolted you can pull it down to see where that plastic piece is. Get a small screw driver and pop the plastic piece out of the hole (It will come towards you) then once the plastic piece is out you will see that the cable portion (just the inner cable itself) will slide up and out of the pedal. There is an opening for it. When istalling the new cable just slide the pedal (pedal still unbolted) up into the metal cable part via the slot and pull back....you will see that the small white plastic piece will just pop right back in where it belongs. The last thing is where the cable goes through the firewall if I remember correctly it goes through and metal fingers pop out to hold it in. You need to release these from the inside of the car. This will all make sense once you are actually doing it.
Chris
Thread starter Similar threads Forum Replies Date
tsiemens Throttle cables removal 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Z removing throttle cable Fox 5.0 Mustang Tech 2
1 Throttle Cable Install/Removal? Anybody done this before? Fox 5.0 Mustang Tech 2
juiced_94gt Can I remove the throttle return sping on the throttle cable?? Fox 5.0 Mustang Tech 1
superstroke17 throttle cable removal and cruise control question Please Help! Fox 5.0 Mustang Tech 1
B how to remove throttle cables from the bracket? Fox 5.0 Mustang Tech 4
jaidedeye TV cable removal on throttle body??? Fox 5.0 Mustang Tech 3
9 Removing throttle cable Fox 5.0 Mustang Tech 1
T Need help with throttle cable. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
S throttle cable snapped 1996 - 2004 SN95 Mustang -General/Talk- 0
S Throttle Cable for Trickflow Streetburner Intake Manifold SN95 4.6L Mustang Tech 0
G What is this plastic piece called? Holds together throttle and tv cable 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
sen2two Throttle Cable Too Long 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
M Engine Throttle Cable Bracket Screw Fox 5.0 Mustang Tech 0
GoldenEagle91 Engine Correct Throttle Cable For Carb'd 94? 1994 - 1995 Specific Tech 2
JonnyBlazeGT Broke A Throttle Cable Braket Bolt 1996 - 2004 SN95 Mustang -General/Talk- 2
B Progress Thread 99 Cobra Throttle Cable SVT Tech Forum 0
JarheadMP Relocating The Throttle Cable Fox 5.0 Mustang Tech 3
M Cobra Intake Cruise/throttle Cable Clip Standoff Part# SVT Tech Forum 1
AUBURN1111 Engine Throttle Cable Questions Fox 5.0 Mustang Tech 6
8 SOLD 99-01cobra 03-04 Mach1 Throttle Cable, New Ford Engine and Power Adder Parts 0
Yellow393 Throttle Cable Set Up On A Carb Conversion? 1994 - 1995 Specific Tech 0
K Need Throttle Cable For 03/04 Mach 1. Drivetrain Parts 0
BANGERSTANGER76 Which Year Nd Make Throttle Cable Work For Fox Tb Swap???? 1994 - 1995 Specific Tech 2
green95stng Slack Throttle Cable. 1994 - 1995 Specific Tech 2
90_Red_LX Throttle Cable Woes...now Holding Tb 1/3 Open Fox 5.0 Mustang Tech 2
L Engine gt500 cable throttle body 2007 - 2014 Shelby GT500 Tech 6
95Vert383AOD Engine Throttle Cable Slack? Fox 5.0 Mustang Tech 6
R Throttle Cable Fox 5.0 Mustang Tech 2
B Cant Find A New Throttle Cable! SN95 V6 Mustang Tech 5
demented22 seat belts, clutch pedal, throttle cable oh my..... 1996 - 2004 SN95 Mustang -General/Talk- 4
98blackstallion 79-85 GT throttle cable? same for TBI as Carb? Fox 5.0 Mustang Tech 6
8 Throttle Cable Mod 1996 - 2004 SN95 Mustang -General/Talk- 27
S Throttle cable problem! Fox 5.0 Mustang Tech 5
8 Throttle cable help SN95 V6 Mustang Tech 0
W fuel pump stuck on/no start and throttle cable slack Fox 5.0 Mustang Tech 6
J converting to carb,will stock throttle cable work and what bracket? Fox 5.0 Mustang Tech 5
N Throttle cable ? Fox 5.0 Mustang Tech 3
P 91 THROTTLE CABLE ADAPTER The Welcome Wagon 3
8 1987 lx 5.0 throttle cable installation Fox 5.0 Mustang Tech 3
Lifted94XLT 4cyl to 302 throttle cable Fox 5.0 Mustang Tech 7
Grn92LX Throttle cable install. Whats this for? (PIC) Fox 5.0 Mustang Tech 10
89mustangt throttle cable Fox 5.0 Mustang Tech 4
N Are auto and std speedo and throttle cables the same? Fox 5.0 Mustang Tech 3
S throttle cable help Fox 5.0 Mustang Tech 6
ID89GT Throttle Cable 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S throttle cable 96-98 cobra = bullitt ? SN95 4.6L Mustang Tech 11
G Throttle lever bushing missing on my car (for the TV cable) Fox 5.0 Mustang Tech 7
a_k Throttle Cable! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
A HELP! Throttle Valve Cable Froze? Fox 5.0 Mustang Tech 0
