  • 2005 - 2009 Specific Tech
Throttle Problem???
  • Thread starter Thread starter Soljer88
  • Start date Start date May 30, 2009
Soljer88
18
  • May 30, 2009
So ive got a small problem. Whenever i push down on the gas there is about a 2.5second delay before the car will start to go.......some friends have told me it was the TPS.....if that is the proplem how might i go about fixing it? Its really annoyn.
ski
380
May 31, 2009
  • May 31, 2009
If your car has the stock tune, then suggest installing an aftermarket tune to eliminate the throttle lag.
klaw
343
Calgary, Alberta, Canada
May 31, 2009
  • May 31, 2009
2.5 seconds? Sounds like a lot of delay. Haven't heard of any stock tunes that bad.
Soljer88
18
  • May 31, 2009
So does anyone else know what it might be?
SpartaPerformance
2,517
61
89
Long Island NY
May 31, 2009
  • May 31, 2009
When did this problem begin?
Soljer88
18
  • May 31, 2009
i just bought the car used from a toyota dealer, so im not sure how long its been goin on...... i can take it back to them but there a pain in the ass so im tryn to do it myself.
02GTRX
I told an admin to shut up...now I live with the S
20+ Year Stangneter
Sep 27, 2004
213
  • Jun 1, 2009
The throttle lag is common on stock tune stangs. I do think you may be exaggerating the 2.5 second time you claim, get a custom tune from bamachips and you'll have instant throttle response.
Posted via Mobile Device
Soljer88
18
  • Jun 1, 2009
I counted to 2.5.....i know thats not completly acurate.....but today i went to auto zone to get the free vehicle diagnostic thing because the check engine light has been on since i got it.....the diagnotic said
Definition
"The IAC circuit condition or idle speed is higher/lower than expected."
Explanation
"The ECM has detected that the IAC counts are higher or lower than expected, the engine speed is not in its expected range."
Problem cause
1. Vacuum leak on engine
2. Dirty throttle body
3. IAC motor defective
4. Poor electrical conncetion to the IAC valve
BlackRod
55
Southern California
Jun 5, 2009
  • Jun 5, 2009
I had this problem. It was the oil coming off of the after market air filter. If you have an after market intake, that could be the problem. Just take the throttle body off and clean around the butterflies. If you have a stock intake, I can't help you.
clentonz
26
#10
  • Jun 6, 2009
  • #10
Really guys..........
Here you go Soljer88, this will 'reset' your throttle position(as it is controlled via the computer).
copy and paste from ResQman over at Hidden/cool features on 2005-2009 Mustangs... - Page 22 - MustangForums.com (read over that tricks/tips post, its got some great info in it)
Recalibrating your Throttle
Recalibrating the throttle by turning the key in the on position and pressing down to the floor ( total 3 seconds ) then release for 3 seconds.
1- Turn the ignition to ON without starting the engine(dashboard lights come on and chime sounds).
2- After the chime stops, smoothly depress the gas pedal to the floor while counting 1001-1002-1003.
3- Release the gas pedal using the same procedure in 2. (total of 6 seconds pushing/releasing)
4- Wait 6 seconds, and turn the ignition to OFF.
5-Start her up and enjoy
**If it is really quiet when you do this, you can actually 'hear' the computer learning/resetting throughout this procedure.....there is a slight 'whine' when you push the gas pedal down/up(it sounds different the faster or slower you go), and 'clicking' sounds during the wait periods
I really hope this helps your throttle lag(dead peddle) problem, it defiantly helped me; good luck man
O
o0Dan0o
485
#11
  • Jun 6, 2009
  • #11
What the two above me said. I'd get some MAF cleaner and TB cleaner, clean both and then recalibrate as explained above.
Dan
Soljer88
18
#12
  • Jun 9, 2009
  • #12
I am gonna go try the computer resetting thing now.....hopefully it works! ill lecha know.
Soljer88
18
#13
  • Jun 9, 2009
  • #13
IT WORKED!!!! clentonz i owe you soooo much! My check engine light even went off
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
CAMTWO1070
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
