I think it depends on how you have your cable adjusted. Do you have slack in your cable? If you do, then maybe it could be the bearing, since when you step on the pedal the bearing contacts the plate and makes the noise. If you don't have slack, the bearing would make noise more of the time then not, since it is always going to be contacting the plate fingers.
