I just had my 2004 GT tuned by a known reputable tuner yesterday when the car started throwing a P0405 - EGR Sensor A Circuit Low. Have you guys heard of this happening before? I believe he just ended up shutting the EGR off after playing with it for about 20-30 minutes. Are there any issues with this? I cleared the code and as soon as I start my car the code re-appears. It hasn't thrown a Check Engine Light though. Is there a way to troubleshoot this before I take the car back to him? He is obviously aware of the problem and counter-acted it by disabling the EGR apparently so I don't think that will accomplish too much.
What issues could I run into in its current configuration?
The only other cause I can think of is we put Marvel Mystery Oil through the small vacuum port on the plenum a week or 2 ago to make smoke and trace an exhaust leak. Whatever didn't get burned off is probably just sitting in my exhaust system. You'd think the car would have burned the rest off by now from the heat but I haven't noticed any smoke. When I had my muffler clamps removed and welded the other day he said there was a decent amount in there.
Could this have gotten to the EGR sensor? I'm a noob and somewhat unsure of how the EGR processs works and how these sensors are linked.
I really don't want to start tracing wires back to my PCM.
Could it be the valve?
I was told it could be a DPFE sensor, but those seem to go for about $40 which I don't want to spend if it really isn't bad and it's just the tune or wiring, or oil that hasn't burned away. If you guys think it'll fix the problem, relating to that code, I'll go pick one up. I read somewhere that if the DPFE sensor is bad it'll probably throw a different code.
This is what Diablosport said...
"If he turned off functions related to the EGR you should not be getting trouble codes. You’ll need to consult with the tuner to see if the custom tune itself needs adjustment.
-Mike M"
-Mike M"
