Timing by ear?
kdog_x
566
The other day I was tightening up my headers and I noticed that one of my spark plugs was loose. I took it out, and it looked kinda burnt (grey), so I checked the manual and it said that overadvanced timing or insufficient cooling could be the problem. The cooling system works pretty well, although it does start a little slower when it's hot. Anyway, whoever owned the car before me put the harmonic balancer on in the wrong position (which I figured out the hard way a few months ago), so when I had to set the timing I did it by ear -- since I really didn't want to have to pull the balancer off.
Is there some way I can test to see if I'm setting the timing right with no light? I did wan't the timing to be advanced for a little performance, but I don't want it too far. It seems like it was lacking power in the 4500-5000 RPM range, but I figured that might just be my imagination. Any help would be appreciated.
I would have to pull the balancer off to set the timing because 0 degrees is not lined up with the mark for it on the balancer. So when you point the timing gun at the mark, you don't see anything.
I found TDC by inserting a screwdriver into the #1 chamber, the 0 degree mark was about 100 degrees off from where it should be, which is why I figured someone probably put the balancer on in the wrong position. Anyway, does anyone know a better way to time by ear?
OH! That explains it. No, there is no better way. I'd say your best fix would be one of those adjustable timing pointers from Reichart or UPR, then you could put it where there's a reading, maybe? Timing by ear isn't a great idea though, even if you're a master tech. You can be 20 degrees off and not even know it.
Sounds like you have a bad balancer, one that has spun off alignment. The balancer is keyed so that it only fits one way when properly installed. If it was installed without the key, you could have some serious problems hiding in the engine waiting to bite you in the rear.
the balancer seems to be tight, I've put over 10,000 miles on it and it hasn't given me any trouble (knocks on wood). Also, if the keyway wasn't lined up shouldn't the balancer wobble, or do something noticable?
nah, the car would probably be running like crap -- if at all. I made sure air was coming OUT of the hole so I'm sure it was the compression stroke.
i wont comment on the balancer stuff but timing by ear works once you know you are close. that is what we ALL do. we time it, and if while driving, we HEAR detonation/ preignition, we back it off. i do time by ear, but check it with a light, so i know what i am at. as i get older, i dont trust me ears to hear faint pinging.
i would rather 'time by ear,' than rely on some random number being right. all motors like different timing. i used to frequently advance till i heard pinging and then back it off a little, never using a light ever. it works for me.
My point was that it should always have a light put on it. Not that timing by ear shouldn't be done, but that you should always know where you are set. While all engines like a little different timing, there are some of those random numbers that they all don't like at all, and it will cause lot's of other issues and you wouldn't hear anything wrong. My timing pointer broke off my timing cover years ago, so we were doing it by ear. My tech is an ASE certified master who has been building and tuning hotrods for twenty years. The car ran strong and didn't make any noises. When I finally bought a new pointer, we saw we had over twenty degees off where we wanted to be. By setting it with a light, it immediately ran cooler, got better milage, and performed better. I only run 91 in it, it won't run on anything lower- and we never got a knock or a ping out of it ever. Use your ears if you want, just as long as you baseline it with a light first and check it with a light when you're done.
You can't put the balancer on in the wrong position - it's keyed - it only goes on one way. If the timing mark is that far off (100 degrees you said?), perhaps it's the wrong balancer for the engine (highly unlikely I'd guess), or someone has installed an adjustable timing pointer that's all out of whack. Not sure - it seems very strange to me. If the balancer was bad and the outer ring had spun, I'd think you'd be getting some noticeable vibrations.
Trying to get a good 'read' on a loose plug doesn't make any sense; and the way to 'read' them is by making a full throttle pass, and immediately shutting off the engine, coasting to a stop and pulling the plug. The circumstances under which you read it were compromised - tighten it back up and focus on the balancer/timing issue before you worry about the plug readings. Also, your engine is basically stock - you should expect it to feel like it's losing power in the 4500-5000 rpm range - the power peak is about 44-4600 rpm. Perfectly normal.
I'd keep investigating the timing issue - something's funky with either your balancer or pointer. But you can't put one on wrong - it's keyed and only goes on one way. Is it possible you clipped your timing light on the wrong spark plug wire? They are easy to confuse up on the distributor - and that would explain your 100 degree off reading and the fact that the car seems to be running ok.
