Timing for Peak Power?
  • Thread starter Thread starter jtstang89
  • Start date Start date Mar 22, 2004
jtstang89
48
Oklahoma
Mar 22, 2004
  • Mar 22, 2004
OK, here's the setup. My 89 LX 5.0 Vert (AOD) is completely stock except for exhaust (flowmaster and h-pipe), and soon to be installed 4.10s !! So what I need to know is what should I set my timing to, to get the best out of my car? This may sound like a stupid question, but when it comes to cars I'm pretty ignorant. Also, what should my timing be in stock form? Thanks in advance for any information.
Zero Signal
2,633
Tucson, AZ
Mar 22, 2004
  • Mar 22, 2004
The stock base timing is 10°. If you really want to bump the timing, I would keep it under 14°, but I don't think you'll get much out of bumping it since the computer is going to try to compensate.
TOM89LX50
235
Philadelphia, PA
Mar 22, 2004
  • Mar 22, 2004
You will almost always get more performance out of advancing your timing unless you are running a power adder or had a chip(super chip, autologic, etc.)burned for the car and installed already. Then you would want to leave it at 10. Mine is set at 18 right now. Every car is different. My combination may like more than someone elses. My setup will like more than yours b/c of the h/c/i/ setup over a stock setup. Go ahead and bump it to 14. It will take that easy. It is also a trial and error thing to be done at the track between rounds to see how the car responds. Your stock computer will not do anything to negate the positive effects of bumping your timing. Tom.
TrophyHead
1,195
11
49
PA
Mar 22, 2004
  • Mar 22, 2004
Try 14 degrees first and if you dont hear any pinging turn it up to 16. My car is currently at 16 and I have a stock motor. Your gonna need to run a higher octane fuel when you bump the timing up.
jtstang89
48
Oklahoma
Mar 23, 2004
  • Mar 23, 2004
OK thanks for the info guys, I just completed a full tune up on the beast, and I will try out the 14 degree timing.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
F
5 lug disc brake pad help
  • Foxrider714
  • Nov 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
KRUISR
The Dilemma! 1988 LX 5.0
  • TTSaleen
  • Sep 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
