  • 1994 - 1995 Specific Tech
Timing woes?
  • Thread starter Thread starter tacodog
  • Start date Start date May 18, 2010
First Prev 2 of 2
HISSIN50
34
129
May 19, 2010
#21
  • May 19, 2010
  • #21
Exhaust gasses are relatively inert. Thus when they are reintroduced, timing can be advanced and injector PW reduced.
stangbangerrick
63
Colonial Hgts, VA
May 20, 2010
#22
  • May 20, 2010
  • #22
I had the same problem with the TPS plug not fitting right had to grind a little metal off the elbow adapter and shim the TPS with some washer this is with a 65mm edelbrock throttle body, I have the GT40 tube intake. With the plug not seated right the tsp reading would jump all over the place when the car was running. When I did my 331 stroker this past winter I bought a 70mm Professional Products throttle body they have added a TPS tuner spacer to their throttle bodies which move the tps about 3/8" further out and allows you the ability to rotate the TPS w/o having to take off the IAC and that extra space allows the plug to the tps to go in with out the clearance issue.
tacodog
27
Canada
May 20, 2010
#23
  • May 20, 2010
  • #23
stangbangerrick said:
I had the same problem with the TPS plug not fitting right had to grind a little metal off the elbow adapter and shim the TPS with some washer this is with a 65mm edelbrock throttle body, I have the GT40 tube intake. With the plug not seated right the tsp reading would jump all over the place when the car was running. When I did my 331 stroker this past winter I bought a 70mm Professional Products throttle body they have added a TSP tuner spacer to their throttle bodies which move the tsp about 3/8" further out and allows you the ability to rotate the TSP w/o having to take off the IAC and that extra space allows the plug to the tsp to go in with out the clearance issue.
I will definately look into their t.b's when i go to replace the stocker, it sure is a cow trying to get in there with a meter, i will have to recheck voltage while its running to make sure its good. It sure was hard to get a good reading in the first place, but I thought it was just due me trying to find the sweet spot in the plug....did the washers at least do the trick afterward, along with the grinding?
First Prev 2 of 2
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
