  • 2.3L (N/A & Turbo) Tech
timming question
  • Thread starter Thread starter BELL
  • Start date Start date Oct 31, 2006
BELL
722
California
Oct 31, 2006
  • Oct 31, 2006
okay so i was going home tonight, a mbz 320 clk rolls up (i've run those to the ground when i work for mbz, with the 86 svo.). 1st is good nice hard pull slight detonation when i push it over 4500 at full boost, 2nd is nice, pulls hard starts to detonate on the top end of 2nd about 4900. 3rd pulls okay but starts to loose momentium around 4200rpm. i've run over clk 420's at 22psi, but the car seems so much faster at 15psi with the timming at 12 degrees btdc. it seems to feel like it runs out of fuel....
someone give me a good set of timming specs i think the FPR should be around 40psi at idle correct me if i'm wrong
Brantley
1,329
Memphis, TN
Oct 31, 2006
  • Oct 31, 2006
Sounds to me like you're definitely leaning out big time.. a hybrid & ported head, etc on stock injectors at 40psi? That's got to be really lean. You can check this by cranking your fuel pressure up about 10 lbs, and see if it helps any. You really need a wide band O2 so you know what's going on, and then from there you can get larger injectors and tune the ECM to get it all working right.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
