Tire Question, please read.
  • Thread starter Thread starter fox racer
  • Start date Start date Jan 2, 2005
fox racer
577
Staten Island, NYC
Jan 2, 2005
  • Jan 2, 2005
ok, heres the deal. i want to kno if a tire off of one rim will fit onto another rim.
The tire I want to use is on a stock turbine rim. Its specs are:
Futura GLS Super Sport P235/60R15
The rim i want to use is an ARE wheel the currently has the following tire on it:
Goodyear Eagle VR60 P225/60VR15
can I simply remove the tire from the ARE wheel, and put the tire from the Turbine rim on it?
how much do you think this would cost if i went to a tire shop? would i need a balance?
The car isnt a daily driver or anything, it wont be a DD till the end of May, but if i went around the block or sumtin would it be ok?
jb89coupe
416
CT
Jan 2, 2005
  • Jan 2, 2005
Yes, it'll fit. They're both 15" wheels, the 235 is a little wider (~ .4") and a bit taller but it will go right on the wheel. Not sure what a tire shop would charge you to swap them but yes you should get it balanced too.
However, if you're planning on putting a 235/60/15 on a car with 3 225/60/15's on it, DON'T. The 235/60/15 is almost .5" taller.
cevtv
1,113
Massachusetts
Jan 2, 2005
  • Jan 2, 2005
A swap and balance can run between $10 and $30....depending on the shop you go to.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
D
9" axle replacement recommendations
  • dobrostang
  • Aug 18, 2022
1965 - 1973 Classic Mustangs -General/Talk- Aug 18, 2022
dobrostang
D
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
