  • 2005 - 2009 Specific Tech
Tire/Rim purchasing - questions
  • Thread starter Thread starter Dreadnaught
  • Start date Start date Aug 30, 2006
First Prev 2 of 2
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Sep 2, 2006
#21
  • Sep 2, 2006
  • #21
for the 255, an 8 inch rim would work. the 275 would only require a 9 inch rim. you can put the 275s on a 10 inch rim, but it may look like the tire is a little too small for the rim.
LuS1fer
80
Caerphilly, South Wales, UK
Sep 2, 2006
#22
  • Sep 2, 2006
  • #22
I agree. I might go for an 8.5" rim for a 255 but 8 is fine. I agree with bigcat about the rear tires. I had 275's on 9" rims on my Z28 and they were fine. I've tried to get 275's on 10.5" rims this time and it's definitely a stretch (the current drifting look...LOL) so I'll be increasing it to a 285 or 295 next time. See, even I get it wrong.
Dreadnaught
31
#23
  • Sep 2, 2006
  • #23
Sounds good guys. I've decided to go with the Carroll Shelby CS67 rim - it's 20x9. However, they are planning to make it in a 18x8.5 and 18x9.5 and by the time I need it, they'll have it out.
With the extra 0.5'' on the width of the wheel for a 255, using knowledge from DML tire calculator and Car Bibles, an 18x8.5 wheel will fit fine on a 255/45/18 tire. However, on a 275/40/18 tire, an 18x9.5 wheel may be a lil too big. When doing the math 275mm = 10.83 inches. On a 275/40 tire, 85% of 10.83 inches is 9.21 inches which rounded to the nearest half inch, is 9 inches. Would the difference between be much using a 18x9.5 on a 275/45 as opposed to an 18x9 on a 275/40?
The reasoning behind using a side wall of 40 and 45 on 275 and 255 tires respectively, is to minimize speedometer/odeometer readings - correct? Does it have anything to do with the stance, or is the the wheel (rim) offset? Likewise a 20x9 would take a 255/35/20, 275/35/20 - according to me using and understanding the calculator?
This should be the last barrage of questions I have on this subject, thanks to you guys for having patience with me and directly me to websites to educate myself. :SNSign:
LuS1fer
80
Sep 2, 2006
#24
  • Sep 2, 2006
  • #24
As I've said, the 9" rim is just about perfect for the 275 but a 9.5" wouldn't be too wide.
Keeping the rolling radius is the target irrespective of what sizes you use although I prefer the consistency of the same profile front and rear and prefer the 35 for tire control (the 55 profile on the stock Mustang is hopeless) but again, pros and cons. the only thing is that whatever you do, the bigger rolling radius should be on the back to maintain the stance. The stock Mustang suspension is a bit like a speed boat anyway, up and down and they look daft with the nose in the air.
Looks like you got a handle on the concept now though and I like the wheel choice.
bigcat
May 1, 2005
3,015
7200 feet
Sep 2, 2006
#25
  • Sep 2, 2006
  • #25
check out this months car craft, as they have the secrets to wheels fitment.
Dreadnaught
31
#26
  • Sep 4, 2006
  • #26
Just when you thought this was over, lol. Upon trying to find Nitto NT-555 in 255/35/20Z for the front tires, I noticed there were none on the list (steeda.com). I then tried to find BF Goodrich 255/35/20, and while I could, I couldn't order them, nor see their specs.
I find it hard to believe Nitto does not have 255/35/20ZR tires, anyone wanna chime in on this (PM me a possible site to purchase from)?
I did find BFGoodrich g-Force T/A KDW at 255/35/20YR, however I was leaning towards Nitto over Goodrich - for no aparent reason other than Nitto sounds cool , if someone wants to chime in on the two brands lol.
Appreciate the help guys and girls.
First Prev 2 of 2
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:18 PM
2000xp8
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
