tire rubbing issue...
Shirley
112
Phoenix, AZ
hey guys. I could use some help on this one. I have the stock pony rims, and every time i turn the wheel to the right, my front passenger side tire rubs against the wheel well. It only happens when i turn the wheel to the extreme right, but the problem i have noticed is that from the wheel well opening (starting where the car door ends) to the edge of the tire i have maybe about an inch to 1.5 inches of clearance on the passenger side, and on the driver side i have about 2 to 2.25 inches of clearance. Also my car leans towad the passenger side, it actually looks slightly lopsided. I am trying to figure out whether my control arms are bent, or if the frame is bent, or is a strut worn out? I had an alignment about a month ago, and the car still pulls slightly to the right. I need help because if the frame is bent on this thing i don't wanna keep throwing money at it. thanks
look and see if the inner fender lining is bent when you pop the hood. If the car was wrecked, that stuff would probably be bent. Someone may have bent it back, but you could probably still tell. I suppose the tires are the same size, but that would matter if they are not. Is the wheel straight when you have the steering wheel straight? Also check and see if your radiator support is bent. That probably wouldn't cause your problem, but they're bent a lot of times when the front end is wrecked from the front.
I'm no expert, just random thoughts; my car was stolen and wrecked in the front about a year ago.
I agree! Also who installed your subframe's shirleys ?If theydidnt have the car level that could be the problem also? I can almost bet you have a wrecked stang at one time? The alignment shop should of noticed this you'd think? peace
john:p
