Tire Rubs..
  • Thread starter Thread starter nugget68
  • Start date Start date Jun 27, 2007
N
nugget68
362
  • Jun 27, 2007
I just put some late model mach I rims on my 68 coupe using the 1" bolt on adapters. My drivers side tire rubs on big bumps. My car is really not as low as I want it, there is a bit of a gap between the top of the tire and the wheel opening, I would like to eliminate that, maybe tucked a little. My tire size is 225/45-17. I have hear of people running 245's with no problem. I have rolled the fenders a little, but maybe not enough...those of you that have rolled your fenders, how much are they rolle, i mean, is it completly against the inside of the fender, or is the lip just bent over...pay no attention to my sig pic my ar is not that low, it is a photochop of what i would like the stance to be...
dodgestang
1,360
Cecil County, MD
Jun 27, 2007
  • Jun 27, 2007
check alignment, if still rubs then perform shelby mod and have re-aligned.
N
nugget68
362
  • Jun 27, 2007
i just had it realigned to 1/8 toe in, -.5 camber, and i cant remember the caster, but that shouldnt have an effect on rubbing...
dodgestang
1,360
Cecil County, MD
Jun 27, 2007
  • Jun 27, 2007
Add more negative camber.
N
nugget68
362
  • Jun 27, 2007
how will that effect handling on a street car...since the new wheels and alignment the car rides more like a boat...when i hit a dip or something the car will pull one way...
rbohm
6,698
550
204
tucson,az
Jun 27, 2007
  • Jun 27, 2007
first thing you have to do is determine where the rubbing is. if it is on the fenders, then you can roll the fenders a bit more until the rubbing stops. if on the inner fenders, then you need a bfh to massage the inner fender panels.
stangman67
294
connecticut
Jun 27, 2007
  • Jun 27, 2007
I machined the front spacers for my mach 1s down to .800", which gave me that little bit of clearance. I had to also grind my upper control arms alittle, and no wheel wieghts on the inside lip.
dodgestang
1,360
Cecil County, MD
Jun 27, 2007
  • Jun 27, 2007
For street/performance the specs I lean towards are:
Caster: +2.0° to +3.0°
Camber: -.5° to -1.5°
Toe: 1/8" in
If your car pulls to one side or another perhaps your alignment guy didn't set both sides close enough to each other, or perhaps you have some bump steer issues to contend with. More negative camber will increase the turning performance for you, however, if you have not performed the Shelby a arm mod you are limited to how much you can run. Also bear in mind, too much and you will start to wear the inner of the tire faster, however, for a simple example I have -3 camber on my 65 and with 3-4 thousand miles on the tires they still do not show any unusual wear pattern from the street use the car has seen.
N
nugget68
362
  • Jun 28, 2007
Toe: 1/8" in
So with these alignement specs you gave, should i go to the +3.0, -1.5, and 1/8, or should I try to hit the median of these? also the car doesnt pull when i am going strait, just when the suspension travels up or down a bit...like if i hit a bump or if the transmission shifts hard...
N
nugget68
362
#10
  • Jun 28, 2007
  • #10
That may be what i have to do...i wonder why the mach I wheels are any ifferent than the other late model wheels?
N
nugget68
362
#11
  • Jun 28, 2007
  • #11
the rubbing is definatley on the fenders, maybe I wil lget a bigger hammer and go back in to roll the fenders some more...
brianj5600
1,964
Middle TN
Jun 28, 2007
#12
  • Jun 28, 2007
  • #12
Moving the upper arm lower, Shelby drop, will help the top of the tire to pull in as it goes up. I would try that first. It is easy and free and will make the car handle better. You will need another allignment though, so much for the free.
N
nugget68
362
#13
  • Jun 28, 2007
  • #13
I should be able to get a free alignment too...my shop class in high school, when I graduated in 2000 we got a new alignment rack that at the time was better than any garage in the tri state had, so if i talk to my shop teacher maybe he will let me take it one day and do it myself...
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:18 PM
2000xp8
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
9
Tire size for "16 Pony wheels on '87-'90 Mustangs
  • 92LX5spd
  • Sep 19, 2022
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 2, 2023
limp
For Sale Cobra II part out
  • 76_Cobraii_mustang
  • Dec 15, 2023
  • Mustang II Parts
3K
Mustang II Parts Oct 31, 2024
78GhiaMustang2
