Actually, you're incorrect. There is nearly an inch difference between the the 225/60/15's and the 245/50/15's. All be it that different manufacturer's differ slightly in size, but there is a considerable difference none the less.HarleyFordFan said:actually the 245/50r15 ia actually within 1/4 inch of the 225/60 r15 tire. my friend had the 245/50 on his 88 and my old 88 had the 225/60 and they were within 1/4 inch height diference. both size tires were bfg's
I’m not saying they wouldn’t fit, but on a 7-inch rim, but they do bow in the center of the contact patch reducing their effectiveness. I bet you’d do just as well with a 255/50 or even 235/60. Not to mention it makes the handling ***** for street use. Too damn much sidewall flex.rd said:I have 275-50-15 BFG Drag Radials on ten holes. Fit fine, with a coil cut out of the springs....
