Tire sizes when using Eibach Pro kit suspension.Will Tires rub?
MustangLX-5.0
856
Lehigh Acres Fla.
Still in the process of installing The Eibach Pro Kit Springs - Pro Dampers and Anti Sway kit.When I bought all of this,I decided to replace all 4 tires.225/55/16 on front and 245/50/16 on back.
My question is,will it rub anywhere after kit is installed? In case some of you didn't know,the springs will lower it 1.2" in front and 1.0" in back.So I don't know if there will be clearance issue...eg ..just turning the sterring wheel or the back tires rubbing against the fender well.If this is going to rub then I can just sell these tires to someone and get a different set.They aren't mounted on yet.
Thanks in advance
I have 255's all the way around and with 17x8's on the fornt its rubs the frame with it in a full turn.The back has a good bit of room with 17x9 even when i had tails.But if i have 4 people in the car and hit a curb my back tires will rub the fender. I would roll them if I knew how.
