TKO install questions
  • Thread starter Thread starter slappypappy
  • Start date Start date Apr 1, 2004
slappypappy
9
  • Apr 1, 2004
TKO going in a 91 mustang...do I have to do anything special at the crossmember? I will be using a Lakewood bell...do I need a new motorplate or will the one off of the stock T-5 bell work? Thanks in advance tonyalester@earthkink.net
DemonGT
871
51
49
Sparta,WI
Apr 1, 2004
  • Apr 1, 2004
the lakewood should come with its own motor plate...crossmember spot welds have to be ground down to let it slide back
V
v8only
2,378
22
49
Apr 1, 2004
  • Apr 1, 2004
the block plate will work fine. Don't forget to get a new driveshaft yoke.
TIMMY2734
1,330
Queens, NY
Apr 1, 2004
  • Apr 1, 2004
no, if hes using the lakewood scattershield, he needs to use the lakewood plate.
V
v8only
2,378
22
49
Apr 2, 2004
  • Apr 2, 2004
crap, my bad. thanks for pointing that out. I usually don't give out bad information like that.
DemonGT
871
51
49
Sparta,WI
Apr 2, 2004
  • Apr 2, 2004
just as i said haha
if you have a brand new TKO it should of came with the correct driveshaft yoke...but if you got it used and dont have it...either find a tremec dealer to get you one...or if you dont already have a alum. driveshaft get the shaft for the mod motors
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
