When I did my TKO, I already had an FMS DS. It was longer than the one that came with the new tranny, and the new one clearanced to Ford specs, so obviously the other one wouldn't. The SN95/T5 DS is also shorter than the Fox, as the input shaft on the T5 is longer, and therefore the bellhousing is as well. This is the shaft I was told I needed, and ordered, which was longer than my original. Don't know what else to tell you.
I didn't realise I was huffy about the speedo gear, looking back at my post I must be missing something. Grn92LX specifically asked what else was involved, and nobody had mentioned it. It's a valid issue to some people, so I did.
I'm glad to hear you haven't had any trouble with your crossmember. Hundreds of thousands of people don't follow the correct stagger sequence when torquing down their lugnuts, don't resurface flywheels when installing a new clutch, don't rotate tires properly, etc, etc, etc, and they never have a problem either. Lucky them. When something isn't recommended by the experts, I tend to listen up whether I think I'll be one of the few unlucky ones or not. That's where I'm coming from, not looking for a pissing contest. I don't need to prove anything, I've put in my time and seen it all already. What you think of my motives for being here is quite simply not my problem- all I did was make points. I say again: didn't mean to step on any toes, I'm anal particular, and you can take it or leave it. It'll look fine from my house either way.
BTW- off topic, but I saw your page. Nice 4 Eye, I like it. Lot of great features. I gave it a 5.
