Augh, I've had my few little problems here and there, and this may just be another one, but I'm starting to get frustrated.
Me and a buddy were having problems getting the TKO to pop in that last 3/4", we struggled with it for about a half hour and we decided that it should be fine to pull on with the bolts. The bolts went in without much trouble at all and we figured we just pulled the tip of the input shaft into the pilot bearing (we made sure the clutch disc was as centered as possible, so it wasn't that). We got everything in and wired and up and the car started fine, but the clutch doesn't feel 'good' (correct) until about 3/4 of the way to the floor. I have the MM kit with the firewall adjuster, but the thing is practically all the way out. I don't think taking it two more threads is going to help. I can't put it in any gear with the car on and the pedal depressed (but at this point in time that could mean nothing). With the car off I struggle to get it into 3rd and 4th, but once I get it into one or the other it slips into both rather easily. I know I for sure put the transmission into 3rd and 4th, and I believe I did every other gear too when it was fresh in the box, but I can't remember for absolute certainty that I did the 4 others, but I'm awfully sure. The pedal doesn't snap back to the top of it's travel, in fact it probably only snaps back 2/3 of the way to the top and I have to manually pull it the rest of the way with my foot. Is the cable too long? The Tremec Bellhousing also relocated where the clutch fork went versus the T5, and we had to cut off part of the first holder for the clutch cable to clear the long tubes, but it didn't effect how everything hooked up under there. I didn't feel like crawling under the car one more time tonight to look at things. What do you guys think, I'm really in a bind here as Spring Break is over after this weekend, and I really don't feel like paying someone to help me make this right. Thanks.
