Engine Top End Kit Install
chizler
56
30
28
Knoxville Tn.
i have a bone stock 1992 lx 5sp with 58k miles, i am in the process of gathering parts for a trickflow top end kit install.
right now i have everything thats included in the kit, plus i have purchased
pro m 75mm maf calibrated for 24# inj.
bbk 70mm tb
adj fuel reg and gauge
24# injectors
autolite sparkplugs
just trying to get everything together before i start tearing stuff apart, is there anything else im missing.
Aside from fluids and assembly lube. Not sure if that's included in the kit or not. If this is your first time doing this I would allow for two weekends to get the job done. Disassembly will take the better part of a day. Make sure to have zip lock bags that you can put screws and various small items in and a marker to label them all with.
Probably need better headers and pipes now that she's gonna breath.
Because of the way some brackets and such have different bolts on the same bracket. I used cardboard and drew templates of each bracket with all holes. As I disassembled I placed each bolt in its corresponding template hole. I also did this with the water pump.
For stuff that had the same hardware I bagged and labeled.
For vacuum lines I marked each one and its corresponding nipple, V1, V2, V3 ect.
I'm going thru this right now and while waiting for parts and such I'm blasting and powder coating everything.
Since its apart you may want to do a new water pump also. There cheap!
Reactions: jrichker
thanks for the heads up on the fluids the kit doesnt come with any but i do have that on my list and the fuel pump is on the way forgot to add that to the list.
i have already swapped the headers and exhaust out on it this past spring, so i am all set there.
this is the 1st time i have dove this deep in to a car but i have a couple of mechanics from work that are going to help me tackle it one weekend.
Reactions: 97gtstang01
head,intake,exhaust, timing cover, thermostat, valve cover gaskets
ARP head, balancer, intake, timing cover, exhaust, water pump bolts
new 192 thermostat
new timing cover seal
are you using the stock rockers and pushrods?
new timing chain and gears
new water pump
new harmonic balancer- I like pioneer
new cap, rotor, wires, plugs
new water temp sending unit, IAT sending unit
new PCV and screen
new radiator, heater, bypass hoses
new vacuum hoses
new serpentine belt
Thermactor plugs for the heads
head dowels
I would check your lifters - at 58k miles they may be ok
If using the stock clutch fan, check the clutch
right stuff RTV
Reactions: chizler
For peace of mind I'd degree the cam (assuming a new cam is part of the top end kit) and verify pushrods are the correct length. In order to do these you'll need a degree wheel, a dial indicator and some way to hold it in place (magnetic base works ok but they also make fixtures to align the indicator perfectly with the pushrods), nut that slips over the crank so you can turn the crank with the degree wheel installed, 2 solid lifters, and a pushrod checking tool and a micrometer that will measure around 6.25".
Sent from my iPhone using Tapatalk
well ive made a little progress in the last few weeks. i got my fuel pump (walbro 190lph) installed, upper and lower rear control arms in and my sub frame connectors installed. im just getting everything up to par for the HCI that should be installed in the next few weeks. will keep you guys posted on how it all goes.
Cylinder head removal & replacement
Revised 25-Aug-2014 to update parts list
Plan on 3 days to do the job if you haven't done it before.
Day one gets the heads off in 4-6 hours. Remove the A/C compressor mount bolts and move the compressor out of the way. The A/C compressor swings out of the way without disconnecting any of the lines or losing any refrigerant. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Day two gets all the gasket surfaces scraped off extra clean and the heads dropped off at the machine shop if you are going to have them reconditioned. Time here is another 4-6 hours. Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Day three starts when you get the heads back from the machine shop. This is the time to pick up all the little odd pieces you found needing replacement on your day two inspection/cleanup. Plan on 6-8 hours to reinstall the heads and reconnect everything. Plan on an additional 2 hours to troubleshoot/adjust everything.
Now for some practical tips:
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern.
The bolts are torqued down in a 3 step process.
Step 1 8 ft/lbs
Step 2 16 ft/lbs
Step 3 23-25 ft/lbs
You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
Put some cardboard in the lifter valley to help catch the gasket scrapings. Have a shop vacuum handy to suck up the scrapings and any coolant that leaked into the lifter valley.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out. Be sure to put a rag or cap in the block where you removed the distributor. It will save you trouble if something falls into the empty distributor hole.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with Blue Silicone gasket sealer and put it together. Whoopee! no leaks, and no gaskets that shifted out of place.
Get a tube of anti-seize and coat all the bolt threads and under the bolt heads. That will help insure even torque when you tighten the manifold bolts. Plan on re-torqueing them after a week’s worth of driving
The cylinder head bolts are reusable, but some new ARP bolts are a better plan. Be aware that the ARP bolts have a radiused shank under the bolt head. The ARP washers have a matching radius machined into them. Be sure that the machined radius of the washer is fitted next to the machined radius on the ARP bolt heads. Forget this little fact and you will never get the head bolts to torque down properly.
Coat the underside of all bolt heads with anti seize and the threads of the long bolts. The short bolts thread directly into the water jacket and need a different treatment. Use Teflon Pipe dope on the threads of the short head bolts. It will prevent any coolant seepage from around the threads. You can get the Teflon pipe dope from the hardware stores, Home Depot or Lowes.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $3-$4 per kit. The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end. The following are listed at the Borg-Warner site ( BWD - Home ) as being resellers of Borg-Warner parts:
Parts Plus - Premium Auto Parts & Accessories or Auto Value / Bumper to Bumper Quality Parts & Service - Home of the Aftermarket Auto Parts Alliance Group or Tires, Auto Parts Stores, Brakes & Automotive Parts | Pep Boys or Federated Auto Parts - Automotive Aftermarket
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer
on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor
to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car
runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back
in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Consumable items:
head gaskets or head gasket kit
Rocker cover gaskets
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Exhaust manifold gaskets.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
Spray can weather strip adhesive to hold manifold gaskets in place
Acetone or MEK to clean gasket surfaces
1 gallon straight antifreeze (same price as 50/50 mix, but a 90 cent gallon of distilled water makes it 2 gallons at a cheaper price)
1 gallon distilled water
ARP antiseize or equal for the bolts
Teflon Pipe dope
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
Machine shop charges will vary - figure $275-$350 to have heads checked for cracks, cleaned, surfaced, valves ground, valve guides reconditioned, valve springs checked and bad springs replaced.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Step 1 8 ft/lbs
Step 2 16 ft/lbs
Step 3 23-25 ft/lbs
in when you finish.
Consumable items:
Teflon Pipe dope
HVAC vacuum diagram
update....... well today was install day.
we started at 5am this morning and had it running by 3pm today (my buddy is a mechanic), complete top end and cam install. amazing how easy everything is when you have all the right parts and tools when doing some thing like this. one took one pic of the process (was to busy working for anymore) but i do have a video of it running i will try to figure out how to do it from my iphone.
just want to say thanks for all the info on this site and the people who helped on the site who replied.
