- Dec 30, 2004
- 246
- 0
- 0
I'm putting on a new set of valve covers and thought I'd check the torque on the rocker arms. They are the factory originals (289) and I've noticed from time to time they seem to be rather noisy. So just for the heck of it I wiggled them by hand to see how tight they were. I have one on the very end that seems to be really loose. Is this just a matter of where the engine is at as far as the compression cycle? Is there a special procedure in tightening that nut down? I have a torque wrench and I think I remember the torque spec to be something like 20-25 ft-lbs.
Could someone please explain it in lamens terms the procedure to properly tighten these? Or do you simply run the wrench across all of these to a set torque?
Thanks!!
Thanks!!
