torque specifications on puttin stuff back together.
hookups333
154
Jax Florida
I need the torque specs for the lower intake, upper intake, valve covers, rocker arms, lifter retainer, water pump, timing cover, cam bolt, crank bolt, the oil pan bolts. I know this is a lot to ask but any help would be appreciated.~Derek
oil pan 106-142 in. lbs
crankshaft damper bolt 110-130 ft.lbs.
camshaft gear to camshaft bolt 40-45 ft lbs.
timing cover bolts 142 in. lbs.
water pump bolts 15-21 ft. lbs.
lifter retainer two drops of locktite on each bolt and tighten very lightly to approx. 5 ft.lbs.
rocker arms seat to cylinder head bolt 18-25 ft. lbs.
valve covers 142-212 in lbs.
