steeda's instructions say torque the crank bolt to 115 ft/lbs. my torque wrench doesn't go to 115 ft/lbs. doesn't even go to 100. i'm not gonna go buy another one, should i just tighten it til my arm is ready to break off?
Weird! When I installed underdrive pulleys, the piece of paper only said to torque it to 60ft lbs. Ya if i were you, if you dont want to do 60ft/lbs. Then just crank on it till it feels good and tight.
one other question. pulleys have been on a week. went back last night to re-tighten & check bolts. crank pulley bolt seemed like it was pretty loose. i mean, not wobbling about to fall off or anything, but still worked loose a bit. should i put loctite on it or something or is this normal? btw, instructions say 85, but steeda has apparently corrected this to 115???
