  • SN95 V6 Mustang Tech
tps and my problem
  • Thread starter Thread starter dastang2
  • Start date Start date Jul 15, 2004
dastang2
2,020
tx
Jul 15, 2004
  • Jul 15, 2004
it runs steady when barely pushing the gas but as soon as the pedal gets to a certain position, the car starts cutting out very histerically. would the tps do this. is the tps on top of the throttle body or on the side.
V
v6asian
29
southern california
Jul 16, 2004
  • Jul 16, 2004
cel light on? when sensors go bad usually light comes on. otherwise it can be anywhere from vacuum leak to a transmission problem.
dastang2
2,020
tx
Jul 16, 2004
  • Jul 16, 2004
no vacuum leaks for sure and i have a manual tranny but i don't see why that has anything to do with the engine cutting out and using a half a tank of fuel in 30 minutes. the engine light has been on way before this problem came up. it came on for a rear o2 sensor malfunction but it ran good still. now that the car was driven backwards into a bayou by my wife and got just the rear of the tank under water everything else failed. clogged injectors, fuel pump is loud now and clogged filter. anyways, i am stumped, i will be taking care of my injectors soon.
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
3rd person help with a Chevy issue
  • LILCBRA
  • Feb 13, 2025
  • Other Auto Tech
Other Auto Tech Apr 20, 2025
LILCBRA
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
