TPS set at 1.23?
I haven't driven the car yet. It's raining.
I DON'T WANT TO DIE!
So is that why the car felt really good at part throttle? I assume since it was saying WOT but it wasn't then there was too much fuel.
noticed no matter where you live our weather is alway's the same? weird.
well I'm betting you fixed it.
-wonder if that was how you could run so much boost w/o an IC though? Alway's telling the computer to make things a tad richer.
Next time we hit the dragstrip you will be :owned:
Hey, sorry to hijack this post, but I adjusted my TPS not too long ago as well. Was set at base of .8 volts and I set it to .96 volts.
I couldn't get the WOT voltage set right though. The Highest I can get it to read is 4.0 volts as opposed to the recommended 4.9 volts. Could my TPS be bad? The throttle plate does open all the way.
Any Ideas on this related problem.
BTW, when I set the base voltage, It corrected my erratic idle problem.
