  • 1994 - 1995 Specific Tech
Track heat upper plenum
  • Thread starter Thread starter parchisi
  • Start date Start date Jul 18, 2006
parchisi
519
New Mexico
Jul 18, 2006
  • Jul 18, 2006
Hey, does anybody know if the TF Track heat upper has provisions for attaching vacuum lines underneath? I ask because for some idiotic reason I put a street upper onto a 408 and I want to upgrade to at least the track heat. Also on that note, does anybody want a black powdercoated street upper?
Pokageek
2,767
MA, USA
Jul 18, 2006
  • Jul 18, 2006
Mine does.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 18, 2006
  • Jul 18, 2006
Get the R upper or the R box if you have the clearance. The track is WAY WAY too small for a 408. Even a std R is too small for a 408. Trickflow only makes an R lower for 351 based stuff.
parchisi
519
New Mexico
Jul 18, 2006
  • Jul 18, 2006
The street intake I have now rubs on the hood already, I had to grind down the intake a little bit. Although I do have the 3/8" phenolic spacer...but I need that in order to clear the throttle body with the tall valve covers. Is the R intake that much taller?
parchisi
519
New Mexico
Jul 18, 2006
  • Jul 18, 2006
I was looking at the trackheat and R intakes, and they say they must be used with 90mm throttle bodies. I've never even seen a 90mm throttle body! Is this true that I need one? if thats true, then the 75mm intake elbow and 75mm mass air flow sensor would kinda be holding up the show as well. And also, this car needs to be emissions legal. Maybe I could solve all my problems by slapping an S trim on this baby.
drakesdad
961
Oregon OHIO
Jul 18, 2006
  • Jul 18, 2006
I have a 70mm TB on mine with NO problems.........and vacuum ? is a yes......it has the provisions
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • dan50
  • Jul 18, 2026
dan50
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
M
  • mnky99
  • Sep 5, 2025
mnky99
M
