track times after trick flow t/e kit
BB 91' NOTCH
md
It's an auto with 3000 stall,shift kit,410's, 19lb fuel injectors,70mm mass air,cai,65mm tb,timing set at 13,street radials and no tune:
60' 1.996
1/8 8.686 @80.32mph
1/4 13.53 @102.12
I think with a little more timing,drag radials,and around 20 degrees cooler I can get real close to 12's.What do you guys think?
The folks at TF recommend 24# injectors, 75mm mass air, 70mm TB and at least a 190 lph fuel pump when I called them before installing mine. If you make the suggested upgrades, you should see 12's for sure.
