Traction....
1988WHTGT
270
Guyton, GA
Ok, All of my mods are in my sig along with a new set of draglite wheels with some 265/15's out back. The tires were on there when I got the wheels. I was running 245's on my Pony's and would just blow them off. Well, same with these new tires. 1st and 2nd are just instant redline and tire smoke. Can't hook to any better than a 2.1 60', 8.6 1/8 and 13.2 1/4. I know it will run 12's, it has to. So, I think I need some ET Streets. Problem is, I've got Tokico Illumina's out back with X2C upper and lower control arms and Eibach Pro Springs with no insulators. So I'm guessing an ET Street is gonna have some clearance problems. The wheels are 15x8 and I was wondering what size ET street to run and also if you think I'm gonna have to put the stock springs back in the back. Any input is appreciated. Thanks.
Just don't get the big fat ETs and you'll be fine. Everyone thinks you HAVE to have the bigass ETs to get traction, but 8 inch slicks will hook just fine for a street/strip car.
Gese. In my H/C/I 331 im running 3.55s as well with 275nittos on the back and 1st gear is pretty useless, but second catches nicely, I wonder what the difference is.
What you need to do is look at tires and suspension. I have eibach drag springs and 7 way adjustable strain struts with the 275 nitto's on drag lites and 4 cyl shocks and struts up front and i hook awesome. Street or strip. Now if you launch at like 4 grand sure your gonna spin a little in 1st. Although i have an AOD but i can stall it up to 25 or 2600 on the street and right after i launch i HOOK and then shoot the juice and blow the doors off most street cars. At the track with slicks i stall it up to about 2800 and shoot the Juice right off the line and i pull the wheels 6 inches.
I run the BFG Gforce drag radials 275/40/17...figured there was no way I could loose traction with those tucked underneath...I was wrong. I would definately go with the M/T ET's
