After getting the stang running again, I fried the clutch cable. How long it was gone…I'm not sure. I got off the freeway, pushed in the clutch and tried to downshift…and it wouldn’t come out of gear. I finally tugged it out, pulled off the side of the road and found that my clutch cable had been resting against the header.
Now, in my haste…I may have forced first gear a bit to get going again. After I picked up speed…I shifter without using the clutch, but rather just matching the rev's to the tranny. Shifting wasn’t forced.
After swapping in a new AutoZone cable…I found the gears were grinding while shifting only when accelerating/decelerating. While at a standstill, they will go into gear with ease. I decided to try the stock self adjusting mechanism on the quadrant…and...well…that didn’t go so well. The stock quadrant broke…and the AutoZone cable seized up. I borrowed an adjustable cable and quadrant from my brother and found no matter how I adjusted the cable the grinding between gears was still there.
So…here are the final symptoms.
Gears grind while moving 1-4 both Up shifting and down shifting. 4-5 doesn’t grind, however 5-4 does. It seems rpm sensitive as well. I can shift without grinding…but the rpms have to be under 1k.
I've yet to check the plastic bushing under the shifter…and I'll check the fluid as well. I'm thinking however that I have some bad syncros. It just seems odd that I go from a great shifting tranny, to one that grinds 1-4 just from frying a clutch cable.
