  • 1994 - 1995 Specific Tech
Trans cooler?
  • Thread starter Thread starter ga94gt
  • Start date Start date Jan 24, 2009
G
ga94gt
138
Ringgold GA
Jan 24, 2009
  • Jan 24, 2009
Needing a trans cooler and I was wondering what size would be good for my car. I have been looking at 15,000 GVW 11" x 4 1/2 wide or 19,000 GVW 11" x 7 1/2 wide.
Are those too big hight and whith wise? OR do i need to be looking for a smaller GVW?
amplifier28
222
  • Jan 24, 2009
anybody? i also want to install a trans cooler? what size is good for a mostly stock stang?
HISSIN50
34
129
Jan 24, 2009
  • Jan 24, 2009
If you'll be doing boost later and you live in a hot climate, I'd go for a 30K BTU cooler. Stacked plate coolers are self-regulating, so overcooling should not be an issue.
Good luck.
G
ga94gt
138
Ringgold GA
Jan 25, 2009
  • Jan 25, 2009
Are either of those too big? Dimension wise
HISSIN50
34
129
Jan 25, 2009
  • Jan 25, 2009
It depends where you'll mount yours and how you mount it. My first one was like 8x11x.75" and IIRC the 30K unit was 11x11x1.5".
I installed the second version on the driver's side, in front of the condenser. I had to modify the PS cooler and the hood support-rod for MY particular install. YMMV. I recommend that you cut out a piece of cardboard that's the size of the cooler you want to get (add in material for mounting brackets and consider the path of the lines) and hold it where you want to install the cooler. This help you see what kind of space concerns you will have.
Good luck.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
