Transmission fluid lines
  • Thread starter Thread starter Edbert
  • Start date Start date Apr 26, 2005
Edbert
3,548
32
109
Austin TX
Apr 26, 2005
  • Apr 26, 2005
Is there any reason not to run large diameter lines from the tranny to the cooler? The stock ones are like 1/4 or 5/16 and I was buying a roll of 1/2 inch line and the assorted fittings and connectors.
I was thinking maybe a pressure drop or something might be seen, or that I might screw something up. Anyone know if it is okay?
69 302/351c
1,147
Walkertown NC, originally Western Mass
Apr 27, 2005
  • Apr 27, 2005
Good question. Wouldn't the stock fittings on the trans and radiator be a natural restriction. I guess a lot depends on pressure for fluid movement.
R
ravenblack67
46
  • Apr 27, 2005
I doubt there would be any improvement as the cooler will restrict the flow. The pressure is not really an issue as output is at low pressure to begin with. Routing would be a problem. I'd suggest a set of good stainless lines.
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Brand New C6 Transmission Pouring fluid
  • Danielperry2003
  • Jun 17, 2025
  • Other Auto Tech
Other Auto Tech Jun 17, 2025
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
