transmission help
natedawg3649
10
MS
I was given a mustang to me and was told that it does not have the original engine it. So i decided to take it out and rebuild it since it had been sitting for about 3 years. Well i got the engine and tranny out and when i went to seperate them the shaft that slides into the torque converter stayed attached and slid out of the tranny somewhat but not all the way. It finally came apart. If i'm correct thats a bad thing but i'm not for sure because i'm used to messing with chevy trannies. I think its an AOD transmission. That shaft is not supposed to come out like that, Correct?
yeah. c4's have an input shaft inside another shaft looking thing with splines, but it doesnt rotate. that is the stator support, for inside the torque converter. then of course the converter hub drives the pump.
aod's are the same way, except there are two input shafts, 1 solid, and the next one around that, which is hollow. then the stator support. So, i guess a c4 converter should "clunk" and go in about three times while youre installing it...and an aod converter should "clunk about four times. i will try to dig up some pictures later. :)
