Transmission help
Rickybob
Ok guys looking for some advice on stall converters. Details are as follows : 351w fresh build all forged internals just had it dynoed at 435hp and 430ish ft/lbs tourque N/A and i have a nitrous kit that i plan on spraying at least a 150 shot. Tranny is a built up c4 man valve body. Tourque on dyno pull was consistent 430's from 3500 - 5500 rpm. Gears are 4:10 with 275 60 15's. What should i be looking for in a converter? What stall?
your best bet is to fill out the spec sheet for the converter manufacturer that you want to go with, as they all vary their stall and size.. Expect to spend around $500 to %600 for a good one.. Silverfox, Circle D, TCI are ones I've used... Avoid B&M
