transmission mount question
Hey. So find the bar which on my car, is on the drivers side, it's usually black, and follow it. It pulls the rear end forward enough to keep your drive shaft correct with the read differential. Follow that. Usually if it drives :poo:tily. You've taken a stethoscope to the motor, no mounts broken, it'll be that. Follow it to the transmission side mount, you'll see a M shaped rubber grommet, and the mount, more than likely loose, being mine just did this. You need to tuck it in there, and swing that bolt back to tight, no more noise. Glad to help anyone questioning it for the future. It's literally just one bolt. Only 1.
