  • SN95 4.6L Mustang Tech
Transmission Problem. Please HELP
  • Thread starter Thread starter king burna
  • Start date Start date Jun 15, 2011
K
king burna
  • Jun 15, 2011
I have a '96 GT and it won't shift past 40 mph. Had it rebuilt and it was fine for a while before it stopped shifting again. I was told by the guy who supposedly rebuilt my transmission that this was happening bc the radiator probably wasn't cooling the fluid and if the transmission got to hot, it wouldn't shift. I need to know if I should spring for a new radiator or send it to another shop and have the transmission rebuilt. Any help guys?
nyuk98gt
1,427
Chesterfield, MO
Jun 17, 2011
  • Jun 17, 2011
king burna,
Sounds a bit fishy. A rebuilt trans ought to shift like a new trans or else there is a problem.
Maybe the valve body is loose and fluid is leaking where it shouldn't and causing a low pressure issue. Maybe the electrical connections are not fully seated. Maybe a solenoid is faulty. Maybe the OD band is not properly engaged. The list goes on.
Can you datalog? If so, datalog and show him what the temperature is and what the transmission is being commanded to do by the computer and what the trans is actually doing.
If you need a better rebuilder, call Darrin at bc-automotive.com. You will not be disappointed and his prices are like getting a family discount.
Last thing, take a look at "Transmissions 101" in the Tech Articles/Transmissions section of TCCoA.com. Excellent articles by Jerry Wroblewski, the man who knows a thing or two about the 4R70W transmission.
HTH,
Chris
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
H
Transmission Help
  • Harman78
  • Feb 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 21, 2025
Harman78
H
