Transmission question
  • Thread starter Thread starter Rk3
  • Start date Start date Feb 2, 2012
Rk3
  • Feb 2, 2012
Hey guys I have a 92 gt convertible that has a world class in it but 5 gear synchro is about gone so my debate is do I send the tranny to get rebuilt with the ford racing kit off late model restoration or do I buy a tremec t5 that has 2k on it. My car is putting down about 350whp with 373s and radials in the back and gets driven at least 20 miles a week so what do you guys think is the better transmission choice? I'm going to assume that when the ad says tremec t5 that's not the really nice tko?
gearheadboy
1,425
177
84
Greencastle Pa
Feb 2, 2012
  • Feb 2, 2012
A Tremec T5 is probably just a newer T5. Tremec builds them now. Shoot an email to "Bangin" Bob Hanlon @ Hanlon Motorsports. He is a Tremec dealer and does Borg Warner and Tremec service and has for 25yrs. He rebuilt mine very reasonable and has all the parts in stock. Tore it down in about 15 min while I waited and SHOWED me what it needed. Works like a champ. Info@hanlonmotorsports.com is the email addy. By the way HE runs a 5spd in his wheels-up Mustang and runs in the 8's.
Rk3
  • Feb 2, 2012
Ya the tremec isn't broken I'm just wondering if it is a better trans then my rebuilt world class would be
TwoToneHatch
170
New Jersey
Feb 2, 2012
  • Feb 2, 2012
How much could you get the Tremec ? A rebuild of your will probally be cheaper I'd recommened you have Hanlon motorsports rebuild the one you already have Bob is a great guy to do bussiness with .
Rk3
  • Feb 2, 2012
It would be almost the exact same price to do either Im just trying to figure out what's the better transmission?
TwoToneHatch
170
New Jersey
Feb 3, 2012
  • Feb 3, 2012
Well you said the one you can buy is a Tremec , i'd find out if the Tremec is a Z-spec trans(T5Z) if so I would grab that .
need4spd90
106
Mountain Top, PA
Feb 3, 2012
  • Feb 3, 2012
the T5 in your 92 is the strongest factory T5 that was produced(90-newer) aside from the cobra. a "tremec t5" is just a t5..your 92 t5 is a" tremec t5"
under a bolt on the side of the gear box there is an aluminum tag...find out what the numbers on the tag say on the 2k mile t-5..chances are that its a pre 1990 or even from a 4cyl and is weaker than the T5 thats currently in your car...if so, it will be a downgrade from what you have now...
Reactions: 2vNotch
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 3, 2012
  • Feb 3, 2012
A Tremec 3550/TKO/TKO 500/TKO 600 is a completely different transmission from a T5. Strong and almost bulletproof unless you run them without proper lubricant or full throttle shift without the clutch.
A Tremec T5 is still the same T5 that is prone to self destruction when used in a street/strip or racing environment
T5, all versions used in 5.0 Mustangs
Tremec 3550/TKO /TKO500/TKO600 AFTERMARKET replacement for T5 - handles racing environments with ease
See http://www.ttcautomotive.com/English/products/tremec.asp for more information - check out the"Light Duty" group, since TTC makes monster transmissions for big trucks as well as passenger cars.
T5 identifier information.
On the tail shaft of the transmission, there will be a stamped aluminum tag. The tag will have a number on it that you can cross reference to the chart below. There is no other way to find out what type of T5 it is without disassembling it. All the rest of the numbers on the outside of the T5 case are part numbers which are not unique to any particular T5 model.
Remember that 94 - 97 T5's have a longer input shaft and can only be used with a 94-95 bell housing unless you modify or replace the input shaft.
T5's used with a 4 cylinder have a 3.93 first gear, reduced torque ratings and an input shaft pilot diameter that is smaller that the T5 used for V6 & V8 engines. The Pilot diameter is .59" compared to the .668" used on V6 & V8 T5's. It requires a different pilot bearing to be used with a V6 or V8. The pilot bearing you need is for a Ford Ranger diesel from AutoZone part #14672
I don't know how you feel about the DYI thing when it comes to gears, some people don't like the idea of working on transmissions. If the DYI transmission fix idea isn't something that you would rather leave to someone else, here are some resources:
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – http://get.adobe.com/reader/
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://www.hanlonmotorsports.com/ also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
T5 Shim kits – best product I have seen in a while… http://www.5speeds.com/t5/shims.html
“The Peel ‘n Place T5 World Class shim kit makes shimming T5 counter gear and main drive gears very easy.”
lxman
279
Avondale, AZ
Feb 4, 2012
  • Feb 4, 2012
I work for www.bieberfever.com in Pheonix. We are an Elite Dealer for tremec trannys and one of their largest dealers. the stock T5 is rated to 330 t lbs of torque. A Tremec T5 is rated to 400HP and 350 Ft lbs of torque. The tremec T5 is a good stock replacement tranny NOT a Performance upgrade tranny. You want a performance upgrade tranny go with the Tremec TKO 500 or 600. Its going to deepend on what gears you are running and what HP and torque you are making when deciding to go with the 500 or 600.
need4spd90
106
Mountain Top, PA
Feb 4, 2012
#10
  • Feb 4, 2012
  • #10
a stock t5 is a tremec t5....Tremec bought out borg-warner and produced the T5 and its parts..
if by "tremec t5" you mean z-spec, then yes, they have a slightly higher tq rating than the stock production mustang t5
no stock t5 was ever rated at 330ft lbs..they were all rated at 300, and the 93 cobra spec was rated at 310
the T5Z(aftermarket) was rated at 330ft-lbs
Rk3
#11
  • Feb 5, 2012
  • #11
Ok thanks for all the info guys I think I'll just beef up my world class t5 for now
need4spd90
106
Mountain Top, PA
Feb 5, 2012
#12
  • Feb 5, 2012
  • #12
you can get an all steel input bearing retainer and a billet cluster support plate to add a "little" extra strength...
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
P
Drivetrain 1988 T5 Grinding going into 2nd gear, '92 Camaro transmission swap or parts?
  • pindude80
  • May 7, 2024
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 11, 2024
LILCBRA
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Manual Transmission Rebuild Resource
  • hoopty5.0
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2025
AeroCoupe
