- Jan 6, 2004
- 2,085
- 5
- 49
Hello everybody. I am trying to preparing myself to break down and buy a new tranny. I recently changed out the clutch cable, quadrant and added a FWA to try to resolve an issue that I though the stock cable was stretched. The problem is that after the transmission gets warmed up, it is really hard to get into gear from a stop. I have adjusted the clutch cable so it engages with the pedal almost all the way out, all the way near the floor and everything in between without any luck. I just received my 3 quarts of red line oil so I am going to change that out as a last ditch effort tonight but what do you guys suggest. I am at a crossroad right now. Should I just have the already weak tranny rebuilt or should I just break down and buy a stronger one. I am looking for the bang for the buck solution and need some help deciding. The stock tranny has 130k on it but all the stuff in my sig was added in the last thousand which probably didn't help it. hehe. Thank you for your time and suggestions.
Kevin
Kevin
