My tremec will not go into gear with the car running. I tried adjusting it and it doesn't help. I tried a brand new cable and it didn't help either. It seems that the clutch is not disengaging. I try putting it in gear and the car trys to roll a little. If I try starting it up with the trans in gear, the car moves as I crank it.
The set up is a tremec tko with gm syncromesh fluid, mcleod DF clutch disk/fms hd pressure plate modified/blueprinted by promotion, mcleod scattersheild, extended fork, fms quad, cable and firewall adjuster. Absolutely no junk. The trans has appx 2k miles on it and the clutch has about 1000 on it. I put a new clutch in with my new motor. This problem has been happening since a few weeks ago but by playing with the adjustment it worked. Now adjusting it doesn't help. WTF?!
