A Tremec 3550/TKO/TKO 500/TKO 600 is a completely different transmission from a T5. Strong and almost bulletproof unless you run them without proper lubricant or full throttle shift without the clutch.
A Tremec T5 is still the same T5 that is prone to self destruction when used in a street/strip or racing environment
T5, all versions used in 5.0 Mustangs
Tremec 3550/TKO /TKO500/TKO600 AFTERMARKET replacement for T5 - handles racing environments with ease
See http://www.ttcautomotive.com/English/products/tremec.asp for more information - check out the "Light Duty" group, since TTC makes monster transmissions for big trucks as well as passenger cars.
Both the 3550 & TKO 500 & 600 use a different bellhousing. TheTKO 500 uses the same clutch disk as the T5. The TKO 600 uses a 26 spline input shaft and a chevy clutch disk.
The 3550 uses the same output shaft yolk as the T5.
Both TKO 500 & 600 use a different output shaft yolk.
