Trick flow Track heat kit?
MY 85 GT
1,852
208
104
New Jersey
Ok i started a post but no-one said much i'll try this who is running a TFS track heat kit...H/C/I i want to purchase this and use my Paxton SN93 blower making 6-8 psi what type of RWHP will i make...im using 42lb injectors,255 lph gss340 fuel pump,Aboco DBX 97 mm maf...I was told tho the Cam wouldnt be so good for my car since its an Auto...i was told to go with a Comp blower cam?,,any ideas on what cam is good from comp?...
I think it's the stage 1 cam? not too bad for your set-up, the package would work nice with a mild blower.
I would say as a guess 360-370 as a guess?? I made 449 to the wheels with a built 331 and 7lbs on a Paxton 1220SL.
A comp cam XE blower series cam like a XE274HR would probably work nice depending on heads and pistons etc.
Trick flow Street Heat kit, Stock bottom end, vortech Si trim stock pulleys, c/4 w/ trans brake, 3.73's , 275/50/15 m/t drag radials. best pass of 10.90 @ 130 w/ 11.0 A/f and 20 degrees total timing. Not sure on the rwhp because we never took it to the dyno, we just tuned it on the street w/ a wide band and pms. so in other words, that should be a potent combo.
Thanks guys...The shop doing my work said i should use the Track heat and go with a blower cam made by Comp do you think thats a good set-up?...I want this car to be in the 12's somewhere do i have a shot?...its an 87 vert with a worked AOD 3.73's...
wow I suck . Like I said I made 449 to the wheels on slicks (with a stock t-5) and drove it like I stole it and could only muster a 11.4 @ 122mph. Good time!
I grenaded my t-5 shortly there after so I'm installing a new C4 this weekend.:nice:
Our car w/ out the blower and aod was only able to muster a 13.0 in its defense the convertor was really tight, but a 12 second pass is not asking too much w/ that combo.
Thanks cobra912
should easily run a 12 even without the blower, but then again not sure how much the automatic plus extra weight of vert is costing. definatly be deep in 12s with a 5-speed coupe. my car with the holley kit runs low 12s at 110. and I think the TF kit makes more HP.
